| Qarl |
Jan 28 2004, 06:15 PM
Shriveled member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
I have a set of fiberglass front and rear bumpers for the conversion car. Purchased from PMS. (Made by someone else, I'm sure).
Anyways, I need brackets that I can glass in so I can use the factory mounting holes. Anyone know of a source? it's not a simple 90 degree bend... it involves some weird angles. Or can anyone post some pictures of another solution? Thanks! |
| maf914 |
Jan 29 2004, 07:55 AM
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None
QUOTE(URY914 @ Jan 28 2004, 07:03 PM) If you can't find a set. I would try make a "buck" out of stroform to get the shape right. It's easy enough to cut and shape and test fit it until it works. Once you get it right, make a aluminum or steel piece. Paul That sounds like a good idea. Perhaps you could form the foam to the right shape, glass it, then glass it to the bumper, and use it for the mount. Figuring out how to locate the bolts might be a trick though. Mike |
Qarl Mounting fiberglass bumpers with brackets Jan 28 2004, 06:15 PM
Eric_Shea Mine are U-shaped mount similar in design to what... Jan 28 2004, 06:21 PM
echocanyons getty has some in there catalog 50$ a pair Jan 28 2004, 06:38 PM
brant I can't remember where...
but 10years ago, we ... Jan 28 2004, 06:51 PM
Qarl Getty Design isn't making them anymore... nor ... Jan 28 2004, 07:13 PM
! Aluminum channel stock....sawzall and a lot of fit... Jan 28 2004, 07:18 PM
Howard A job I haven't done since this morning! ... Jan 28 2004, 07:53 PM
URY914 Damn, I just cut mine out of my front bumper. It w... Jan 28 2004, 08:50 PM
URY914 If you can't find a set. I would try make a "b... Jan 28 2004, 09:03 PM
campbellcj I have a front bumper from GT that has built-in f/... Jan 28 2004, 10:34 PM
maf914 Karl,
Hmm... Didn't you start out with metal... Jan 29 2004, 09:53 AM
Qarl no metal bumpers. I started out with big ugly rubb... Jan 29 2004, 11:32 AM
maf914 Yeah, I remember the 75, but I thought on your sit... Jan 29 2004, 02:35 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th March 2026 - 12:14 AM |
