> Ignition coil maladies, bosch coil testing
thesey914
post Jan 27 2004, 04:00 PM
My engine is not starting, I have fuel but it seems no spark. Changed the ignitor back to points and still no luck.
I'm suspecting the coil -its one of those bosch blue coils. I seem to remember that the blue coil has a ballast resistor so values between the contacts should be about 3-5 ohms. What is the rating for contact and the main lead terminal .....does the resistor affect this value? I have 10k upwards in my mind.
Anyone one have any numbers or advice? (IMG:style_emoticons/default/wacko.gif)
Update....I have just read that one shouldn't use a conventional coil with a CD ignition unit.....which I have just hooked up. Perhaps I've blown it up
thesey914
post Jan 29 2004, 09:07 AM
Well changed back to points because the problem became obvious when I investigated properly. The ignitor was cooked.
I'll source another one because the lobes on the distributor are quite worn, although my CDI has pulse synthesising circuitry (or so it claims)...
Does anyone know if the condensor is necessary when running a CDI?
- Lo-Fi Version Time is now: 11th July 2025 - 12:39 PM
