My Cleanup & Detailing Thread |
jonferns |
May 5 2008, 08:07 PM
Advanced Member Group: Members Posts: 2,081 Joined: 29-March 07 From: New Jersey Member No.: 7,631 Region Association: North East States |
I've been spending alot of my free time doing some detailing work in the wheel wells while the car was up on jackstands awaiting a replacement fuel pump. The idea was to detail the four wheel wells. On the fronts I was left with large dark spots where there was a thick buildup of road crud; the paint isn't chipped in those areas, and the spots come out when I scrape at them with my fingernail, but the spot is just too large to remove all of it that way. I was looking to see if anyone else has dealt with something like this. Maybe some sort of rubbing compound will contain just enough abrasives to remove it without harming the paint underneath? All in all, not bad for almost 40 year old paint in a vulnerable spot.
Also, the struts are left with some spots after cleaning them, what could I use to clean them up. Pat, think that "simichrome" would be a good idea to use on them? |
dcheek |
Apr 12 2009, 05:26 AM
Senior Member Group: Members Posts: 691 Joined: 30-May 06 From: Westfield, New Jersey Member No.: 6,103 |
Jonathan,
I want to congratulate you on such a thorough cleaning job. It's amazing what you will find when you dig this deep. Just a couple of comments: -While I don't have proof that the factory didn't use Shutz, I would have to agree with George at A/A that it looks like they used a fairly thick mixture of paint in a pressure feed gun to give the finish a pronounced orange peel effect. I defer to the Brothers Paterek on that one, they must know the answer. -As far as cleaning a greasy trans or engine; 30 years ago I went to a Paterek workshop and they used plain old kerosene with a brush. There was a miserably neglected 356 for the demonstration. They heated up the engine, covered the distributor cap with plastic and brushed liberally with kerosene. Then hosed off with a strong stream of water. I know it sounds downright primitive, but it worked! I continue to use this method on my tranny, not the engine, since it never really gets that dirty. The trouble with store bought engine cleaners is that they are too aggressive and leave blotches and totally strip any protection you would have on the parts. And I would have to agree with Pat that the oven cleaner is too caustic for plating, seals and paint. The kerosene leaves everything clean and won't remove the finish on painted or plated surfaces. As with any procedure, whatever works for you is correct. I just though I would put in my two cents. Dave |
Lo-Fi Version | Time is now: 5th June 2024 - 10:24 PM |
