> Wallys914/8 Conversion and Restoration, The Build Up Continues, and Continues, and Continues
wallys914
post Nov 23 2008, 06:28 PM
In life you don't get what you want, you get what you negoia
I have had this car since last august, this july the resto/conversion started from the ground up.....Today i stand with the car body work 80% complete and the powertrain build about 20% Complete......Please Critique and Credit, anything you like.....
Original Car like a week after purchase
(IMG:http://www.914world.com/bbs2/uploads_offsite/i328.photobucket.com-9631-1276914834.1.jpg)
Car after new tires, headers, clutch, carbs from fuel injection, and new muffler.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i328.photobucket.com-9631-1276914834.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i328.photobucket.com-9631-1276914834.3.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i328.photobucket.com-9631-1276914835.4.jpg)
After a lil paint and some New tires and wheel adapters <--- Bad IDEA
(IMG:http://www.914world.com/bbs2/uploads_offsite/i328.photobucket.com-9631-1276914835.5.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i328.photobucket.com-9631-1276914835.6.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i328.photobucket.com-9631-1276914835.7.jpg)
3 day stripping paint
(IMG:http://www.914world.com/bbs2/uploads_offsite/i328.photobucket.com-9631-1276914835.8.jpg)
Interior after some stripping...
(IMG:http://www.914world.com/bbs2/uploads_offsite/i328.photobucket.com-9631-1276914835.9.jpg)
Car after more parts stripping....
(IMG:http://www.914world.com/bbs2/uploads_offsite/i328.photobucket.com-9631-1276914835.10.jpg)
computers4kids
post Apr 13 2009, 08:17 AM
Love these little cars!
The water pump is a big block V-8 Chrysler water pump. The gasket should be a Fel-Pro 11730.
You may have an issue with the front of the driver's side valve cover hitting the firewall behind the driver's seat. Very tight. Mine is extra tight because I am also running an engine pad. A lot of the guys have to dent the wall in a bit. I chose to run a mid height valve cover.
Before you install the motor, decide how you going to time the motor and rig-up a new TDC mark that you will use that will be more easily visible either below or above the engine. Some time it through a trunk hole using the flywheel mark.
Look at some of the V-8 theads on throttle linkage. Some buy a longer cable and run it under the engine and up the front on the driver's side...some even up the passenger's side. Renegade has you use the stock cable and come up the firewall. It works fine but it's quite a sharp turn both upwards and again to face the carb arm.
Good Luck,
wallys914   Wallys914/8 Conversion and Restoration   Nov 23 2008, 06:28 PM
wallys914   back of car before grinding http://i328.photobuck...   Nov 23 2008, 06:30 PM
jc914   GREAT JOB Keep us all posted. Nice work on the Fl...   Nov 23 2008, 06:33 PM
wallys914   I got the rockers off to find the driver side in g...   Nov 23 2008, 06:34 PM
wallys914   So I got the Front Suspension off this last week I...   Nov 23 2008, 06:37 PM
wallys914   Engine from Canadia http://i328.photobucket.com/...   Nov 23 2008, 06:39 PM
wallys914   So heres the front control arms and the arm mount ...   Nov 23 2008, 06:42 PM
computers4kids   Great job on the flares...you're an amazing we...   Nov 23 2008, 06:43 PM
wallys914   I had issue breaking the Hood hinge Bolts, I drill...   Nov 23 2008, 06:47 PM
wallys914   Again after a large amount of work, I got the trun...   Nov 23 2008, 06:51 PM
wallys914   I got the Oil tank in, the 6 Mount in and the the ...   Nov 23 2008, 06:54 PM
wallys914   I like the stock tensioners with the 25 upgrade i ...   Nov 23 2008, 06:57 PM
6freak   I like the stock tensioners with the 25 upgrade i...   Nov 24 2008, 01:22 PM
veltror   Brillinat work!! Wish mine was like yours...   Nov 24 2008, 10:22 AM
jjemg   OK... Who is the better welder? She looks like she...   Nov 24 2008, 11:23 AM
wallys914   I think I may have some issues..... :confused: h...   Nov 24 2008, 11:26 PM
wallys914   So i was playing with the hood this evening, and i...   Nov 29 2008, 11:05 PM
Wilhelm   Getting the motor mounts off not so hard. Find th...   Nov 30 2008, 02:50 AM
wallys914   I wanted to know if the barrels above can be clean...   Dec 3 2008, 05:40 PM
rfuerst911sc   I wanted to know if the barrels above can be clea...   Dec 3 2008, 06:15 PM
Lavanaut   Damn, it must be fun to have these kinds of skills...   Dec 4 2008, 11:08 AM
jaybird840   Welcome to the world of the 2.7! I'm abou...   Dec 5 2008, 10:51 PM
wallys914   So it has been a few weeks since I updated this p...   Dec 25 2008, 01:03 AM
wallys914   So after the cleaning and the welding time to get ...   Dec 25 2008, 01:04 AM
FourBlades   I love this thread! Great work. Your welding...   Dec 25 2008, 11:33 AM
J P Stein   In no particular order: There are better rust conv...   Dec 25 2008, 11:49 AM
J P Stein   Another. There are a lot more where these came fro...   Dec 25 2008, 11:52 AM
wallys914   Another. There are a lot more where these came fr...   Dec 25 2008, 12:05 PM
J P Stein   You may find this thread interesting. http://foru...   Dec 25 2008, 12:04 PM
J P Stein   A drill press, vice, & hole saws are good for ...   Dec 25 2008, 12:23 PM
wallys914   so today I got some work done on the cage, i got t...   Dec 25 2008, 11:33 PM
LarryR   Nice bending work. However I think I would get ano...   Dec 26 2008, 12:07 AM
LarryR   Here is a pic of a 914 cage by one of the best in ...   Dec 26 2008, 12:16 AM
wallys914   Well it is up about 4 inchs from the top of the se...   Dec 26 2008, 12:40 AM
J P Stein   Go to the SCCA website and read the rules on helme...   Dec 26 2008, 07:03 AM
Solo914   Go to the SCCA website and read the rules on helm...   Jan 11 2009, 06:52 PM
J P Stein   Go to the SCCA website and read the rules on hel...   Jan 11 2009, 07:30 PM
Solo914   [quote name='Solo914' post='1120487' date='Jan 11...   Jan 12 2009, 01:32 PM
wallys914   So you're all right, it should be about 2-3 in...   Dec 26 2008, 03:01 PM
J P Stein   So you're all right, it should be about 2-3 i...   Dec 26 2008, 06:03 PM
wallys914   So Last night, I added 2 1/2 inches to the main ho...   Dec 27 2008, 03:04 PM
wallys914   Door Bars got bent and got tacked in today, Progre...   Dec 28 2008, 08:49 PM
wallys914   Got the last piece of the halo in, http://i328.ph...   Jan 3 2009, 01:46 PM
bam914   Is the tubing ERW or DOM? If it is ERW hopefully ...   Jan 3 2009, 02:04 PM
wallys914   Cage is welded in, Last week..... http://i328.pho...   Jan 11 2009, 03:03 PM
J P Stein   Well......see attached pic. The problem is not whe...   Jan 11 2009, 06:25 PM
wallys914   Well i know i didnt Tie it in where you wanted it ...   Jan 12 2009, 12:24 AM
wallys914   Long Time no Chat. Nothings been going on here muc...   Feb 23 2009, 12:05 AM
al weidman   Chris, I was wondering when the V8 part was going ...   Feb 26 2009, 10:51 PM
VOX   sweet project, i'm planning on putting a roll ...   Feb 27 2009, 03:05 AM
wallys914   So the Porsche Gods were with me this week, so I s...   Apr 4 2009, 11:13 PM
So.Cal.914   I could come and help you clean out that garage Ch...   Apr 4 2009, 11:42 PM
wallys914   So here are some pics of the RH kit on the motor, ...   Apr 13 2009, 12:12 AM
Andyrew   Awesome build! Looks like you sorted your cage...   Apr 13 2009, 01:06 AM
computers4kids   The water pump is a big block V-8 Chrysler water p...   Apr 13 2009, 08:17 AM
wallys914   Any one know where I can get the water pump 90 deg...   Apr 14 2009, 10:56 AM
wallys914   So its been awhile! I got Scott's Built ...   May 3 2009, 08:50 PM
wallys914   So its been a while since i moved and got the car ...   Jul 12 2009, 05:03 PM
Zaney   Love the GT bumper and valance combo! Will ...   Jul 12 2009, 08:42 PM
wallys914   The Car moved on it's own will today! :Qar...   Dec 12 2009, 09:05 PM
wallys914   Today I took her out on her maiden voyage and made...   Dec 26 2009, 08:45 PM
Travis Neff   Sorry to hear about the enigne troubles. They alw...   Dec 26 2009, 10:37 PM
wallys914   So it's been a while, the car got all the bugs...   Jun 18 2010, 08:29 PM
Andyrew   :DRUNK: :headbanger:   Jun 18 2010, 08:34 PM
wallys914   I guess I never posted any progress, all new parts...   Jan 6 2011, 10:46 PM
wallys914   And now its back from the shop motor in, and away ...   Mar 23 2011, 08:13 PM
Andyrew   Awesome stuff!!!! I like the trea...   Mar 24 2011, 09:36 AM
- Lo-Fi Version Time is now: 14th July 2025 - 01:33 AM
