adjustable rear coilovers |
jmargush |
Apr 13 2009, 11:34 AM
Member Group: Members Posts: 460 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
I am looking at Coleman racings threaded coilover kits. They have an I.D. of 2.040. When I measure my Koni Yellow sports I get 1.968 O.D. on the shock tube. Will their threaded sleeve be too loose? Does it need to be tight?
Also what length springs should I look for 10"? Any thing else I need to know when I make this purchase? |
J P Stein |
Apr 13 2009, 12:14 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
I used .020 inch thick plastic shim stock wrapped around my 2.0 inch dia. Bils.....the yellow stuff on the bench. 10 inch springs in the pic.
BTW, the cable ties weren't strong enuff. Multiple wraps of safety wire did the trick. Had to do some backyard engineering to get the hats to fit around the flanged barrel nut. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 8th June 2024 - 03:44 AM |
