Did They Ever Make A Bicycle Rack For A 914? |
Allan |
Apr 30 2008, 02:37 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Just curious if there was ever a factory or dealer option for a bike rack.
I only know of 1 person who has a system for mounting a bike to his car but it was a standard rack that had to be modified. |
JeffBowlsby |
Apr 30 2008, 02:41 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
At least one MFR offered a bike rack. I have a couple photos on my collectibles webpage. Not a good rack...
Tom_T |
Apr 5 2009, 05:56 AM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
At least one MFR offered a bike rack. I have a couple photos on my collectibles webpage. Not a good rack... I've had the Hardt Bike Rack which I bought in 1978 specifically for the 914s, from Chick Iverson Porsche/Audi in Newport Beach CA. It's design emulated the ski rack which clips the front mount under the front of the windshield/targa-top juncture, & the rear portion screws into the 2-3 holes in the underside of the rear of the roll bar. It always worked great for me - even on long freeway trips, but it was only holding lightweigt 10 speed bikes - not heavier beach cruisers or mountain bikes, so I can't say how they would do. I also had the same design for the ski racks. In both cases you do NOT have to dis-mount the skiis or bike to open the rear trunk, as you do with those racks which attach at the rear tow hook screw adapter & span to the other on the roll bar. I thought was a bad design - especially since the bike seat on those latter's rubbed on the rear deck/trunk lid, & both the skis & bike were at an angle - thereby causing more aerodynamic drag & disturbance. Whereas, the ones I have span parallel & over the targa top, which of course you cannot remove while using these racks - their only drawback. I still have both in the 914 accessories/etc. boxin my garage waiting to be used again! I'd recco those to anyone wanting them! |
Tom_T |
Apr 16 2009, 03:04 AM
At least one MFR offered a bike rack. I have a couple photos on my collectibles webpage. Not a good rack... I've had the Hardt Bike Rack which I bought in 1978 specifically for the 914s, from Chick Iverson Porsche/Audi in Newport Beach CA. It's design emulated the ski rack which clips the front mount under the front of the windshield/targa-top juncture, & the rear portion screws into the 2-3 holes in the underside of the rear of the roll bar. It always worked great for me - even on long freeway trips, but it was only holding lightweigt 10 speed bikes - not heavier beach cruisers or mountain bikes, so I can't say how they would do. I also had the same design for the ski racks. In both cases you do NOT have to dis-mount the skiis or bike to open the rear trunk, as you do with those racks which attach at the rear tow hook screw adapter & span to the other on the roll bar. I thought was a bad design - especially since the bike seat on those latter's rubbed on the rear deck/trunk lid, & both the skis & bike were at an angle - thereby causing more aerodynamic drag & disturbance. Whereas, the ones I have span parallel & over the targa top, which of course you cannot remove while using these racks - their only drawback. I still have both in the 914 accessories/etc. boxin my garage waiting to be used again! I'd recco those to anyone wanting them! FYI -- Here are some pix of the 2 racks - 1 each side for 1 bike each (pic 1 here), & a close-up of the instructions showing them installed & carrying 2 bikes (next post). As I noted above - they always worked fine for me - even at freeway speeds - so long as you set them up properly & cinched down the straps at BOTH the seat plate/pad & handlebar rack, & check them at every stop. My original post above was INCORRECT in stating that the bikes went across the top - only my ski racks did so. The next post shows how they actually worked. Sorry about the "half-zymers"! ...but it's been 25+ years since I last used them! NO - they're not for sale, but could probably be reporduced from similar plate steel, hooks/nuts & straps. HARDT B14 - BIKE RACK FOR 914: note that the protective pads which fit under the lower plates that hook under the trunk deck lid have gone missing above at the one in the lower right corner. That pad to protect the trunk lid finish could be replaced - probably with a better & more soft material faced foam pad of modern materials today. ...also see next post for instructions detail.... |
Tom_T |
Apr 16 2009, 03:16 AM
At least one MFR offered a bike rack. I have a couple photos on my collectibles webpage. Not a good rack... I've had the Hardt Bike Rack which I bought in 1978 specifically for the 914s, from Chick Iverson Porsche/Audi in Newport Beach CA. It's design emulated the ski rack which clips the front mount under the front of the windshield/targa-top juncture, & the rear portion screws into the 2-3 holes in the underside of the rear of the roll bar. It always worked great for me - even on long freeway trips, but it was only holding lightweigt 10 speed bikes - not heavier beach cruisers or mountain bikes, so I can't say how they would do. I also had the same design for the ski racks. In both cases you do NOT have to dis-mount the skiis or bike to open the rear trunk, as you do with those racks which attach at the rear tow hook screw adapter & span to the other on the roll bar. I thought was a bad design - especially since the bike seat on those latter's rubbed on the rear deck/trunk lid, & both the skis & bike were at an angle - thereby causing more aerodynamic drag & disturbance. Whereas, the ones I have span parallel & over the targa top, which of course you cannot remove while using these racks - their only drawback. I still have both in the 914 accessories/etc. boxin my garage waiting to be used again! I'd recco those to anyone wanting them! FYI -- Here are some pix of the 2 racks - 1 each side for 1 bike each (pic 1 here), & a close-up of the instructions showing them installed & carrying 2 bikes (next post). As I noted above - they always worked fine for me - even at freeway speeds - so long as you set them up properly & cinched down the straps at BOTH the seat plate/pad & handlebar rack, & check them at every stop. My original post above was INCORRECT in stating that the bikes went across the top - only my ski racks did so. The next post shows how they actually worked. Sorry about the "half-zymers"! ...but it's been 25+ years since I last used them! NO - they're not for sale, but could probably be reporduced from similar plate steel, hooks/nuts & straps. HARDT B14 - BIKE RACK FOR 914: note that the protective pads which fit under the lower plates that hook under the trunk deck lid have gone missing above at the one in the lower right corner. That pad to protect the trunk lid finish could be replaced - probably with a better & more soft material faced foam pad of modern materials today. ...also see next post for instructions detail.... ...and here's a shot of the instructions......sorry for the cropping so tight, but my camera take 8.0MP pix & I had to cut this to <500mb to post - apologies! DETAIL OF INSTRUCTIONS FOR HARDT B14 - BIKE RACK FOR 914: Good Luck to those looking to recreate these, as they're not too complicated a design. Just make sure to include rubber-type pads at all contact points of the holder parts to body & bikes, and I used to use soft fabric loops over the straps to protect the bikes' finishes too. They're also coated with a rubberized black paint to protect the body surfaces & bikes, and use the 3 standard Porsche allen head screws up under the roll-bar on each side to attach the 2 handlebar holders. The rest of the straps & hardware are probably generally available in the home improvement &/or fabric stores around town. Hope this helps! |
Lo-Fi Version | Time is now: 8th June 2024 - 09:27 PM |
