> Won't Start after conector problem., No spark. Why? PLEASE HELP!!!
old9one4
post Apr 18 2009, 08:57 PM
72' car with 71' wiring (assembled in Dec 71') so no oil tempurature wire in ingition harness.
While searching for oil temp wire I didn't replace the ignition harness connector back on the relay board correctly. It was tilted at an angle with the #1 pin end possibly not contacted. Motor would not turn over. Fuel pump started but no cranking. Tried to jump thinking battery was low. With no help from jump I reviewed my previous actions.
When I found the tipped connector I pushed it back down to the correct contact problem. Now motor turns over and fuel pump works but no start. Only thing I can think of is no spark but, don't know why.
Any thought on this? Coil damaged or worse alternator damaged?
- Lo-Fi Version Time is now: 1st August 2025 - 03:00 AM
