old9one4 |
Newbie ![]() Group: Members Posts: 35 Joined: 1-March 07 From: Sunnyvale, CA Member No.: 7,574 Region Association: Northern California ![]() |
72' car with 71' wiring (assembled in Dec 71') so no oil tempurature wire in ingition harness.
While searching for oil temp wire I didn't replace the ignition harness connector back on the relay board correctly. It was tilted at an angle with the #1 pin end possibly not contacted. Motor would not turn over. Fuel pump started but no cranking. Tried to jump thinking battery was low. With no help from jump I reviewed my previous actions. When I found the tipped connector I pushed it back down to the correct contact problem. Now motor turns over and fuel pump works but no start. Only thing I can think of is no spark but, don't know why. Any thought on this? Coil damaged or worse alternator damaged? |
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
Check all of your fuses!
Lo-Fi Version | Time is now: 1st August 2025 - 03:00 AM |
