| kpfoten |
Apr 19 2009, 06:59 PM
Member ![]() ![]() Group: Members Posts: 220 Joined: 15-April 08 From: Escanaba, MI Member No.: 8,927 Region Association: None |
My sensor seems different (No wire coming off sensor) than what is available. My engine tin has a small hole for it, and I'm wondering if I have to take the tin off? Do I need the bracket attached? Engine is a 1.7L. Thanks!
| 3d914 |
Apr 19 2009, 07:15 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
Kris,
The reason its different is because that's the Air Temp Sensor #1 (of two - the other is smaller and in the plenum -air box) The head temp sensor is about the diameter of your finger, with threads on one end and the lead wire you were expecting on the other end. Take a look at Pelican Parts Catalog for more details. It will also show location. Good luck. |
kpfoten How do I install my head temp sensor -- D-jet (retrofit project) Apr 19 2009, 06:59 PM
kpfoten Thanks!
Where does the #1 Air Temp Sensor mo... Apr 20 2009, 10:14 AM
perrin1097
Thanks!
Where does the #1 Air Temp Sensor m... Apr 20 2009, 10:10 PM
kpfoten Much thanks! This has been fun--hopefully I... Apr 20 2009, 10:17 PM
Cap'n Krusty You've just thanked someone for the WRONG INFO... Apr 20 2009, 10:56 PM
kpfoten No, I just thanked him for the web links... :)
I ... Apr 21 2009, 07:46 AM
kpfoten
Here's a photo that will give an idea (alth... Apr 21 2009, 08:59 AM![]() ![]() |
Lo-Fi Version | Time is now: 29th November 2026 - 07:20 PM |
