| jcambo7 |
Apr 21 2009, 11:34 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,702 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest |
So I am covered in dirt and fuel and I feel great! (IMG:style_emoticons/default/piratenanner.gif) My 914 started up today for the first time. (IMG:style_emoticons/default/aktion035.gif) Took a few times after priming it through the pump and than putting fuel into the throttle body but it runs. It does idle too high right now and that is the next problem I need to fix. (IMG:style_emoticons/default/headbang.gif) I tried adjusting the idle control screw. That didn't seem to work. Oh well...I was just so excited to hear it actually start and run instead of conking out like it did the first like 10 or so tries. (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/piratenanner.gif) I will be uploading a youtube vid of it and posting the link for everyone to see it.
(IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/drunk.gif) (IMG:style_emoticons/default/aktion035.gif) |
| koozy |
Apr 21 2009, 11:44 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 654 Joined: 21-July 07 Member No.: 7,931 Region Association: None |
If the air bleed screw has no effect on idle speed your idle mixture is likely lean. Try turning the ECU knob clockwise, one click at a time and readjust the air bleed screw until you get the proper idle speed. A CO meter is best but this method works too. If you find the idle speed knob has no effect the throttle switch may be misadjusted.
| jcambo7 |
Apr 21 2009, 11:46 PM
If the air bleed screw has no effect on idle speed your idle mixture is likely lean. Try turning the ECU knob clockwise, one click at a time and readjust the air bleed screw until you get the proper idle speed. A CO meter is best but this method works too. If you find the idle speed knob has no effect the throttle switch may be misadjusted. Ok, please explain to me where the ECU knob is if you don't mind. |
jcambo7 Started my 914 for the 1st time today! Apr 21 2009, 11:34 PM
Phoenix 914-6GT :Qarl: :beer2: :headbanger: :driving: :woohoo: Apr 22 2009, 12:01 AM
jcambo7
:Qarl: :beer2: :headbanger: :driving: :woohoo... Apr 22 2009, 12:19 AM
koozy The ECU knob is on the ECU... ha ha ha
OK, sorry... Apr 22 2009, 12:06 AM
koozy BTW: Congrats on getting it started. Apr 22 2009, 12:06 AM
jcambo7
Ok, that... Apr 22 2009, 12:16 AM
Grelber It's happy dance time! :Qarl:
Looks li... Apr 22 2009, 07:15 AM
por73914
Looks l... Apr 22 2009, 08:02 AM
jcambo7
[quote name='Grelber' post='1160810' date='Apr 22... Apr 22 2009, 10:17 AM
jcambo7
Looks l... Apr 22 2009, 10:26 AM
Sleepin Sweet! Good job man! I was rooting for you... Apr 22 2009, 08:25 AM
jcambo7
Sweet! Good job man! I was rooting for yo... Apr 22 2009, 10:27 AM
dw914er :D
happy dance time Apr 22 2009, 10:19 AM
jcambo7 Here is the youtube vid link I recorded of it runn... Apr 22 2009, 10:24 AM
Phoenix 914-6GT James, check the timing asap. Apr 22 2009, 11:18 AM
jcambo7
Y? Do u think the... Apr 22 2009, 11:28 AM
Phoenix 914-6GT Yes, it can also make it hard to start like the so... Apr 22 2009, 05:58 PM
swl
Yes, it can also make it hard to start like the s... Apr 22 2009, 07:28 PM
PanelBilly All right now enough of the happy dance, you'v... Apr 22 2009, 07:12 PM
championgt1 :agree: with Jon. Get the timing checked right awa... Apr 22 2009, 07:26 PM
jcambo7
:agree: with Jon. Get the timing checked right aw... Apr 25 2009, 11:33 AM
Sleepin http://www.vwbughead.com/412fast/412manualtrans/91... Apr 25 2009, 11:38 AM
McMark Make sure you have a throttle return spring on it. Apr 25 2009, 11:46 AM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 08:12 PM |
