| MrKona |
Dec 5 2008, 02:48 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
Is the Dansk OEM muffler a flat gray or a satin gray? Does anyone have a good paint match? Pictures make it look almost like a primer. Thanks...
| Scott S |
Apr 21 2009, 04:51 PM
Small Member ![]() ![]() ![]() Group: Members Posts: 1,698 Joined: 30-April 03 From: Colorado Member No.: 633 |
I guess I would have to understand what you mean by "restored". If it were me, the car would first have to be completely taken apart, then new front and rear clips installed. Then throw it on a rotissory and media blasted to see what is actually left.
I dont know how many 73 2.0's have 72 build dates - I would guess there would be quite a few. Dont dealers usually start getting the following year cars in the fall? Perhaps you are more hands on than me, but that looks to be a big dollar restoration. If your end result is simply to get it operational again, I guess I can see that. Just looking at the pics, I could see dropping 20k (maybe more) into a full resto. |
| Tom_T |
Apr 22 2009, 07:02 PM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
I guess I would have to understand what you mean by "restored". If it were me, the car would first have to be completely taken apart, then new front and rear clips installed. Then throw it on a rotissory and media blasted to see what is actually left. I dont know how many 73 2.0's have 72 build dates - I would guess there would be quite a few. Dont dealers usually start getting the following year cars in the fall? Perhaps you are more hands on than me, but that looks to be a big dollar restoration. If your end result is simply to get it operational again, I guess I can see that. Just looking at the pics, I could see dropping 20k (maybe more) into a full resto. What are "new front and rear clips" ???? (IMG:style_emoticons/default/confused24.gif) excuse my 914 parts terminology ignorance!? ...do you mean new front & rear bulkheads or body panels? - vs. straightening mine? I'd guess about half the 73 MY 2Ls would've been built in 1972 - or a bit less with it being a new model/engine, since they usually switch over MY production about June, and I've seen a 72 & 73 1.7 both with 6/72 production dates on their VIN plates. Mine is #424 GA out of 1954 total 73 914s - so that's about 20% of the total 73s up to Sept. 72 production date of mine - say in the 1st 3 months. So I'd guess-timate perhaps 800-900 2Ls were built during 72, and the rest of the 73-2Ls later. And #424 may not represent a true 1st 25% of the total 73-2Ls built, because there was a ramping up on the early 2.0's, and I can recall waiting lists and a crush to try to get the early ones coming out during calendar 1972. Ergo, I thought mine with an early engine & VIN numbers - but past the odd "first 1000" or so with mixed pre-73 & 73 parts, might be worth saving!? ...I know, they all are! Scott - what you're referring to as a "restoration" - I would call a "Frame Up Full Rebuild," which is NOT what I'm proposing to do with mine. You can damage too many parts in that process - forcing you to replace just about everything, thereby driving up your costs probably closer to $30k with all the NLAs today, and can undo a lot of stuff done in the factory which we have no way of replicating today - possibly leading to damage, more rust (if that's even possible), unsafe roadability, etc. However, I keep getting the confusion over a complete strip down to bare body/uni-body as the only ostensibly "true" restoration. In my day - and I AM an old fart now! (IMG:style_emoticons/default/howard.gif) or nearly so at 56-57 - that full strip down & redo was called a "frame up rebuild" or "strip to frame rebuild"! Whereas, a "restoration" was leaving the car largely assembled - only removing what must be taken off to repair & restore damage &/or to ease the repaint & repair work process, and perhaps stripping the surfaces to be repainted to bare metal if necessary to get a good finish. Pat Garvey's is probably a good example of this, unless he too did a "Frame-up Rebuild"? The latter is what I'll be doing & not for concours, but rather to maintain the originality, value & structural/mechanical integrity of the car. Back in the 60's I helped my Uncle do a frame-up rebuild on his "barn find" (literally) 58 Vette, so I know the diff! And when you get into "Antique Car" circles (over 50 years old) - which the 914s soon will be & some 356s are already - it is considered preferable & more valuable to have a well "restored" car with a maximum number of well kept original parts still intact & unmolested - as they say - versus a completely "frame up rebuild" where nothing much is still original from the factory. These are 2 entirely different processes, and generally recognized within other collector car circles - so why the confusion here at 914world? Can Pat or some other CWs weigh in here on my apparent ignorance on this terminology regarding 914s???? ...what should I be calling my project's "goal" - so I don't keep corn-fusing everybody here??? (IMG:style_emoticons/default/confused24.gif) |
MrKona OEM muffler color? Dec 5 2008, 02:48 PM
tod914 http://www.nlaparts.com/store/exhaust-grey-paint-p... Dec 5 2008, 06:43 PM
Pat Garvey
Is the Dansk OEM muffler a flat gray or a satin g... Dec 5 2008, 06:44 PM
sendjonathanmail The NOS muffler that I have for my '74 1.8 is ... Dec 5 2008, 06:48 PM
Pat Garvey
The NOS muffler that I have for my '74 1.8 is... Dec 5 2008, 07:08 PM
1970 Neun vierzehn
The NOS muffler that I have for my '74 1.8 i... Dec 5 2008, 07:23 PM
sendjonathanmail Pat, my muffler has survived 34 years without any ... Dec 5 2008, 07:25 PM
MrKona Great info everyone! I just bought a used stoc... Dec 5 2008, 08:15 PM
tod914 I got that info from John Patterak. He said he se... Dec 5 2008, 10:00 PM
914runnow
Is the Dansk OEM muffler a flat gray or a satin g... Jan 19 2009, 10:40 PM
Tom_T I have a question about the OEM Muffler for a ... Apr 17 2009, 11:24 PM
tod914 Tom, no chrome tips. Just grey. Apr 17 2009, 11:55 PM
Tom_T
:huh: REALL... Apr 19 2009, 04:34 AM
MDG Tom, what Tod means is the original mufflers where... Apr 19 2009, 07:30 AM
1970 Neun vierzehn
When new, back in the day, no chrome.
:agre... Apr 19 2009, 11:46 AM
Tom_T
Tom, what Tod means is the original mufflers wher... Apr 19 2009, 01:50 PM
sendjonathanmail My muffler is NOS, with the grey coating, also I h... Apr 19 2009, 12:06 PM
sendjonathanmail I've seen a few NOS 2.0 mufflers for sale over... Apr 19 2009, 02:51 PM
MDG I have the newer style Dansk on '73; works jus... Apr 19 2009, 03:29 PM
Tom_T
I have the newer style Dansk on '73; works ju... Apr 20 2009, 01:36 AM
Tom_T ...FRONT END DMAGE
:unsure:
...AND..... Apr 20 2009, 01:41 AM
Tom_T ...LF HEADLIGHT ASSEMBLY
<_<
...AND...... Apr 20 2009, 01:43 AM
Tom_T ...FRONT CHROME BUMPERS, TOPPER & L&R ... Apr 20 2009, 01:48 AM
Tom_T ...MASHED TITTIES
:shades2:
...AND...... Apr 20 2009, 01:51 AM
Tom_T ...REAR CHROME BUMPER & TOPPER & BOTH FULL... Apr 20 2009, 01:53 AM
Tom_T ...BATTERY TRAY & SUPPORT + MISC HELLHOLE SURF... Apr 20 2009, 01:57 AM
Tom_T ...RUST ROT AT PASSENGER-SIDE FRONT FLOOR PAN
... Apr 20 2009, 02:05 AM
Scott Schroeder Man....
do you have an attachment to that car? E... Apr 21 2009, 11:05 AM
Tom_T
Man....
do you have an attachment to that car? ... Apr 21 2009, 11:54 AM
sendjonathanmail I think that what Scott was trying to say is that ... Apr 22 2009, 08:22 PM
Tom_T
I think that what Scott was trying to say is that... Apr 22 2009, 09:30 PM
Scott Schroeder I totally disagree. If you have a relatively strai... Apr 23 2009, 09:54 AM
Tom_T
I totally disagree. If you have a relatively stra... Apr 23 2009, 02:52 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:38 PM |
