> reading engine by piston build up?
detoxcowboy
post Apr 21 2009, 08:16 PM
Region Association: Africa
I am curious if someone could say why i have a respectable amount of carbon build up on pistons 1 and 4 but not on 2 and 3? Is this a sighn of anything or style of runing condition.. ?? It is the first time i have seen my pistons since purchase last year any info is good info.
r_towle
post Apr 22 2009, 07:37 PM
Custom Member
When was this motor rebuilt? how many miles?
Your rings did not seat...but you still need to put in new rings.
I cant really see those pics that well...they need better focus and each cylinder needs to be shown with the piston at the bottom of the stroke.
Rich
perrin1097   reading engine by piston build up?   Apr 21 2009, 08:16 PM
kwales   Oil leaking past the rings?   Apr 21 2009, 08:23 PM
perrin1097   Oil leaking past the rings? o.k. waht if it is ...   Apr 21 2009, 08:50 PM
r_towle   FI or carbs?   Apr 21 2009, 08:52 PM
perrin1097   FI or carbs? 74 2.0 fi.. It is just the 2 fow...   Apr 21 2009, 09:22 PM
kwales   Hard dry crusty carbon sounds like cooked oil. Se...   Apr 22 2009, 05:47 PM
r_towle   It may also be that the injectors are not balanced...   Apr 22 2009, 06:33 PM
perrin1097   It may also be that the injectors are not balance...   Apr 22 2009, 06:49 PM
r_towle   did you hopefully re-ring the motor??? You might a...   Apr 22 2009, 06:51 PM
perrin1097   did you hopefully re-ring the motor??? You might ...   Apr 22 2009, 07:00 PM
r_towle   take a very focused, high resolution picture of th...   Apr 22 2009, 07:03 PM
perrin1097   i can see cross hatching thats all i know.. nothi...   Apr 22 2009, 07:22 PM
perrin1097   another one..   Apr 22 2009, 07:25 PM
perrin1097   RE: reading engine by piston build up?   Apr 22 2009, 07:26 PM
r_towle   When was this motor rebuilt? how many miles? Your...   Apr 22 2009, 07:37 PM
perrin1097   When was this motor rebuilt? how many miles? You...   Apr 22 2009, 07:44 PM
r_towle   http://www.aircooledtechnology.com/store/home.php?...   Apr 22 2009, 07:47 PM
perrin1097   Perfectly done towle.. why not.. nice lead they ha...   Apr 22 2009, 08:01 PM
Todd Enlund   Those are 2.0 bus pistons... are the rings the sam...   Apr 23 2009, 10:50 AM
- Lo-Fi Version Time is now: 1st August 2025 - 06:39 PM
