budman5201 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 595 Joined: 1-April 07 From: tempe, az Member No.: 7,635 ![]() |
ALL 5 new syncros, 2 new sliders, adjusted per specs...... What are the symptoms of this rebuild? VERY Hard to shift at first? Its not in a running car yet, but mounted under it. It shifts VERY hard, will this get better as everything gets worn in? How long does that take?
Oh forgot to meantion, lubed up gears before install and shifted tough but fine through all gears on bench. But installed so far and tried it with no oil in tranny yet. I am assuming it will get a little easier with oil, but WOW it is stiff thanks for your advice (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/driving.gif) |
sww914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None ![]() |
It will get a lot better as soon as you use it a little bit. It feels worse with a short shifter if you have one.
Lo-Fi Version | Time is now: 13th July 2025 - 06:53 PM |
