| detoxcowboy |
Apr 24 2009, 08:58 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
I have a 1974 2.0 with Reman Heads that are getting cc'd. Upon futher investigation it turns out I have VW Bus Pistons. I would like to put New Stock 914 Pistons in to replace these. I understand compresion math and deck hieght, shimming etc.. But would like to know what do I need to do Mechanically to do the swap without causing me more problems than I started with.. Car has run really well and is only getting reman heads because of a broken chunk with helicoil attached came off with exhaust hanging stud... Suposedley the car engine was rebuilt 8000 miles ago but i do not know the extent nor do I beleive anything I was told when I bought the car anymore though I do not think I was lied too just a differ of what is restored and what is rebuilt.. I would like to get away with the minumum right now and crack the case later when I am more edjucated and know better what I want out of my engine.. Stock is fine with me now and may stay that way but would hate to rebuild a car that runs well ..spend a lot more money getting it stock rebuilt only next year to decided i want more power or torque..
What is the respectable safe minumum to a Piston Swap like this.. |
dr914@autoatlanta.com I would certainly, since you have it apart, spring... Apr 24 2009, 09:10 AM
perrin1097 I got it now, form a previous question.. Thanks Ca... Apr 24 2009, 12:27 PM
type47 The good Dr gives sage advice but I would look int... Apr 24 2009, 12:45 PM
perrin1097
The good Dr gives sage advice but I would look in... Apr 24 2009, 02:41 PM
914pwer I got a 2,0 with Type-1 94mm pistons from a friend... Apr 24 2009, 02:26 PM
perrin1097
I got a 2,0 with Type-1 94mm pistons from a frien... Apr 24 2009, 02:35 PM
r_towle Put the heads back on...save your money and buy a ... Apr 24 2009, 07:06 PM
perrin1097
Put the heads back on...save your money and buy a... Apr 24 2009, 07:55 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 03:34 AM |
