| detoxcowboy |
Apr 24 2009, 08:58 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
I have a 1974 2.0 with Reman Heads that are getting cc'd. Upon futher investigation it turns out I have VW Bus Pistons. I would like to put New Stock 914 Pistons in to replace these. I understand compresion math and deck hieght, shimming etc.. But would like to know what do I need to do Mechanically to do the swap without causing me more problems than I started with.. Car has run really well and is only getting reman heads because of a broken chunk with helicoil attached came off with exhaust hanging stud... Suposedley the car engine was rebuilt 8000 miles ago but i do not know the extent nor do I beleive anything I was told when I bought the car anymore though I do not think I was lied too just a differ of what is restored and what is rebuilt.. I would like to get away with the minumum right now and crack the case later when I am more edjucated and know better what I want out of my engine.. Stock is fine with me now and may stay that way but would hate to rebuild a car that runs well ..spend a lot more money getting it stock rebuilt only next year to decided i want more power or torque..
What is the respectable safe minumum to a Piston Swap like this.. |
| dr914@autoatlanta.com |
Apr 24 2009, 09:10 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,235 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I would certainly, since you have it apart, spring for 2.0 914 p and c and if you could the euro style. That way you would instantly get more power in an fairly easy bolt on kit.
perrin1097 Piston Swap used VW bus to NEW stock 2.0, What Else? Apr 24 2009, 08:58 AM
perrin1097 I got it now, form a previous question.. Thanks Ca... Apr 24 2009, 12:27 PM
type47 The good Dr gives sage advice but I would look int... Apr 24 2009, 12:45 PM
perrin1097
The good Dr gives sage advice but I would look in... Apr 24 2009, 02:41 PM
914pwer I got a 2,0 with Type-1 94mm pistons from a friend... Apr 24 2009, 02:26 PM
perrin1097
I got a 2,0 with Type-1 94mm pistons from a frien... Apr 24 2009, 02:35 PM
r_towle Put the heads back on...save your money and buy a ... Apr 24 2009, 07:06 PM
perrin1097
Put the heads back on...save your money and buy a... Apr 24 2009, 07:55 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 04:32 AM |
