| detoxcowboy |
Apr 24 2009, 08:58 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
I have a 1974 2.0 with Reman Heads that are getting cc'd. Upon futher investigation it turns out I have VW Bus Pistons. I would like to put New Stock 914 Pistons in to replace these. I understand compresion math and deck hieght, shimming etc.. But would like to know what do I need to do Mechanically to do the swap without causing me more problems than I started with.. Car has run really well and is only getting reman heads because of a broken chunk with helicoil attached came off with exhaust hanging stud... Suposedley the car engine was rebuilt 8000 miles ago but i do not know the extent nor do I beleive anything I was told when I bought the car anymore though I do not think I was lied too just a differ of what is restored and what is rebuilt.. I would like to get away with the minumum right now and crack the case later when I am more edjucated and know better what I want out of my engine.. Stock is fine with me now and may stay that way but would hate to rebuild a car that runs well ..spend a lot more money getting it stock rebuilt only next year to decided i want more power or torque..
What is the respectable safe minumum to a Piston Swap like this.. |
| r_towle |
Apr 24 2009, 07:06 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Put the heads back on...save your money and buy a whole kit for a 2056.
The 96mm pistons will run using the stock FI and its a very proven setup. Dont piece it together...especially if you are not experienced at pulling cylinders and swapping pistons without doing damage. If you get new pistons, you need to recondition YOUR rods. Then you should probably get new crank bearings for the rods. All of that can be done without opening the case...but at this point you are 20 bolts away from opening up the case and doing it right. So....put the heads back on, drive it till winter, then pull out the motor and do it right. RIch |
| detoxcowboy |
Apr 24 2009, 07:55 PM
Put the heads back on...save your money and buy a whole kit for a 2056. The 96mm pistons will run using the stock FI and its a very proven setup. Dont piece it together...especially if you are not experienced at pulling cylinders and swapping pistons without doing damage. If you get new pistons, you need to recondition YOUR rods. Then you should probably get new crank bearings for the rods. All of that can be done without opening the case...but at this point you are 20 bolts away from opening up the case and doing it right. So....put the heads back on, drive it till winter, then pull out the motor and do it right. RIch towle, you just stated what i thought through today.. does not make sense to go 40% or 60% especially the age of these cars and it does not make sense not to have everything balanced out and checked to work properly fitted with new parts,, i read ahead to someone else whom just did what i was pondering and he made it about 150 miles, now his case is open.. thanks .. |
perrin1097 Piston Swap used VW bus to NEW stock 2.0, What Else? Apr 24 2009, 08:58 AM
dr914@autoatlanta.com I would certainly, since you have it apart, spring... Apr 24 2009, 09:10 AM
perrin1097 I got it now, form a previous question.. Thanks Ca... Apr 24 2009, 12:27 PM
type47 The good Dr gives sage advice but I would look int... Apr 24 2009, 12:45 PM
perrin1097
The good Dr gives sage advice but I would look in... Apr 24 2009, 02:41 PM
914pwer I got a 2,0 with Type-1 94mm pistons from a friend... Apr 24 2009, 02:26 PM
perrin1097
I got a 2,0 with Type-1 94mm pistons from a frien... Apr 24 2009, 02:35 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 03:33 AM |
