Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,808 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
I got everything mounted and installed for the front a arms minus struts and torsion bars. It requires about 20#s of force applied at the ball joint to move the arm up/down. Driver side is half that. Both sides move without any tight spots. I've tried putting washers between the front bearing retainer/body and I've even got one of those front retainers mounted upside down so the bearing is closer to the body (this was a little helpful). FWIW this car has no evidence of any accident or rust. Is this too much force required to move them. Are there any negative aspects if I left it this way. Whats the deal with their low friction mounts? Will this benefit me or is there something else I can do? (IMG:style_emoticons/default/screwy.gif)
ericread |
The Viper Blue 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California ![]() |
So just to be straight, you installed the poly-bronze bearings and you are experiencing some significant friction?
Have your greased the bearings using the zirc fittings? Sounds like your've got some binding in the A-Arm mounts. Mine moved up and down pretty easily (prior to installing the struts and torsion bars). Or there might be the possibility that when you installed the brass sleeves, they went on at an angle. Seem like a problem to me. Take everything apart, take some pics and please post close-ups of the brass sleeves. Eric Read |
Lo-Fi Version | Time is now: 9th July 2025 - 01:26 PM |
