> Elephant polybronze front susp bushings, i don't want to spend another $200 on low friction mounts
Krieger
post Apr 26 2009, 07:50 PM
I got everything mounted and installed for the front a arms minus struts and torsion bars. It requires about 20#s of force applied at the ball joint to move the arm up/down. Driver side is half that. Both sides move without any tight spots. I've tried putting washers between the front bearing retainer/body and I've even got one of those front retainers mounted upside down so the bearing is closer to the body (this was a little helpful). FWIW this car has no evidence of any accident or rust. Is this too much force required to move them. Are there any negative aspects if I left it this way. Whats the deal with their low friction mounts? Will this benefit me or is there something else I can do? (IMG:style_emoticons/default/screwy.gif)
Krieger
post Apr 26 2009, 08:26 PM
This bushings are installed correctly and greased.
Krieger914   Elephant polybronze front susp bushings   Apr 26 2009, 07:50 PM
ericread   So just to be straight, you installed the poly-bro...   Apr 26 2009, 08:15 PM
Krieger914   This bushings are installed correctly and greased.   Apr 26 2009, 08:26 PM
r_towle   That should be fine...the car wieghs enough. The p...   Apr 26 2009, 08:48 PM
charliew   If it's just one side the arm could be slightl...   Apr 26 2009, 09:18 PM
Krieger914   It can't be bent, I already painted it. :hissy...   Apr 26 2009, 10:01 PM
Lou W   Mine were tight too, but I agree with what Rich sa...   Apr 26 2009, 10:03 PM
Wilhelm   If the bushings rotate easily on the arm before th...   Apr 26 2009, 10:40 PM
Phoenix 914-6GT   For those sugesting it should be wrong I will have...   Apr 27 2009, 12:12 AM
Lou W   Thanks Wilhelm and Jon, looks like I'll be tak...   Apr 27 2009, 09:44 AM
kwales   Might want to check the outer diameter of the arm ...   Apr 27 2009, 10:37 AM
gopack   I noticed the same thing on my car after i assembl...   Apr 27 2009, 10:59 AM
rhodyguy   try lossening the attachment bolts, 'jostle...   Apr 27 2009, 12:21 PM
ChrisNPDrider   :agree: I just did my bushings too. I spent a lot...   Apr 27 2009, 01:37 PM
Krieger914   This setup is for the 914/6 I'm building. The...   Apr 27 2009, 06:50 PM
Wilhelm   Also try bolting down one end versus the other and...   Apr 27 2009, 08:52 PM
ChrisNPDrider   More babble to share My 914 body was bent and new ...   Apr 28 2009, 09:25 AM
- Lo-Fi Version Time is now: 9th July 2025 - 01:47 PM
