Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,808 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
I got everything mounted and installed for the front a arms minus struts and torsion bars. It requires about 20#s of force applied at the ball joint to move the arm up/down. Driver side is half that. Both sides move without any tight spots. I've tried putting washers between the front bearing retainer/body and I've even got one of those front retainers mounted upside down so the bearing is closer to the body (this was a little helpful). FWIW this car has no evidence of any accident or rust. Is this too much force required to move them. Are there any negative aspects if I left it this way. Whats the deal with their low friction mounts? Will this benefit me or is there something else I can do? (IMG:style_emoticons/default/screwy.gif)
Wilhelm |
Member ![]() ![]() Group: Members Posts: 408 Joined: 7-September 07 From: Hooterville, OR Member No.: 8,088 Region Association: None ![]() |
If the bushings rotate easily on the arm before the arm is a attached to the car that would suggest something is bent. If after the arm is attached to the car and it binds in one position this would suggest the arm is bent. If it binds in all positions, this would suggest the frame mounts are not inline (bent body). Try loosing the front 2 pivot bolts and swing the arm up and down a few times to see if the front pivot point can seek its "natural" position. The hole are a bit elongated to allow some adjustment. Does that tow ring on the front have elongated holes? If not, it may be limiting your adjustment.
Lo-Fi Version | Time is now: 9th July 2025 - 01:18 PM |
