> Is this all I need?, Injector Leaks
rigglet
post Apr 27 2009, 05:59 AM
Seems like I've read there are multiple seals for the injectors, but this is the only part listed on PP...
http://www.pelicanparts.com/catalog/shopca...j_pg1.htm#item1
I tried stating my '71 after her long winter nap and found that I had a fuel leak from around one of the injectors. (IMG:style_emoticons/default/mad.gif)
She won't start, which is probably a good thing given the leak, and since I'm going to have to remove the injectors as part of the troubleshooting I figured I may as well replace the seals.
Oh...I should mention it is a stock 1.7 in the car. (IMG:style_emoticons/default/biggrin.gif)
Thanks all!!!
Bartlett 914
post Apr 27 2009, 07:31 AM
Where are they leaking? If they are leaking around the base, they may not be usable. Send them out to Curzinperformance. They can clean them and find out if they leak. As for the seals, the small one seals the pintle at the intake. The large one doesn't seal anything. It is used to hold the injector in place.
- Lo-Fi Version Time is now: 22nd August 2025 - 02:11 PM
