> Is this all I need?, Injector Leaks
rigglet
post Apr 27 2009, 05:59 AM
Seems like I've read there are multiple seals for the injectors, but this is the only part listed on PP...
http://www.pelicanparts.com/catalog/shopca...j_pg1.htm#item1
I tried stating my '71 after her long winter nap and found that I had a fuel leak from around one of the injectors. (IMG:style_emoticons/default/mad.gif)
She won't start, which is probably a good thing given the leak, and since I'm going to have to remove the injectors as part of the troubleshooting I figured I may as well replace the seals.
Oh...I should mention it is a stock 1.7 in the car. (IMG:style_emoticons/default/biggrin.gif)
Thanks all!!!
rigglet
post Apr 27 2009, 08:07 AM
I'm not exactly sure where it's leaking from. I'll have to look closer. At ~$16 per injector it is probably worth just sending them off to be inspected and cleaned. Will be on less thing to do later.
Cap'n Krusty
post Apr 27 2009, 08:55 AM
Cap'n Krusty
QUOTE(rigglet @ Apr 27 2009, 07:07 AM) *
If they're leaking, it's NOT the seals, which serve ONLY as air seals, sealing the injectors to the manifolds. Furthermore, cleaning the injectors WILL NOT deal with leaks. If the injector body is leaking, there IS NO repair. First determine whether the leak is at the hose or the injector. If it's the hose, replace the offending part. If it's the injector, replace the injector. The Cap'n
underthetire
post Apr 27 2009, 09:19 AM
QUOTE(Cap'n Krusty @ Apr 27 2009, 07:55 AM) *
- Lo-Fi Version Time is now: 22nd August 2025 - 02:11 PM
