> Is this all I need?, Injector Leaks
rigglet
post Apr 27 2009, 05:59 AM
Seems like I've read there are multiple seals for the injectors, but this is the only part listed on PP...
http://www.pelicanparts.com/catalog/shopca...j_pg1.htm#item1
I tried stating my '71 after her long winter nap and found that I had a fuel leak from around one of the injectors. (IMG:style_emoticons/default/mad.gif)
She won't start, which is probably a good thing given the leak, and since I'm going to have to remove the injectors as part of the troubleshooting I figured I may as well replace the seals.
Oh...I should mention it is a stock 1.7 in the car. (IMG:style_emoticons/default/biggrin.gif)
Thanks all!!!
rigglet
post Apr 27 2009, 09:52 AM
Fair enough. I've been trying to look through the forums to find a post I know I've seen in the past relating to replacement injectors. IIRC there are a few different injectors out there that are reasonable replacement for the stock injectors. Maybe that was only true for the 2.0, but I can't find anything to the contrary.
Can someone with better searching skills point me in the right direction, please.
- Lo-Fi Version Time is now: 22nd August 2025 - 02:13 PM
