> Intermittant idle and losing power, Fuel lines clear to the fuel filter
Trav012000
post Apr 27 2009, 01:37 PM
Awhile back I sealed my gas tank to prevent the rust flakes from getting into my fuel lines and causing this exact problem I'm about to explain.
A couple days ago I was driving her home when she felt like she was hesitating. It would still drive, it'd just hesitate if I pressed down too hard. So I came back the next morning and tried starting it up, the idle was jumping dropping every once in awhile. Now I'm to the point that if I hit the gas while parked it will rev up, then die like it's starved of fuel. The fuel pump working fine, I pulled off the fuel line on the other side of the fuel filter and the pressure looked okay.
Anyone have any suggestions. I did pick up some pistons and cylinders over the weekend that I'm hoping to put in in the next few weeks since one of mine doesnt make any compression and another only makes about half. (IMG:style_emoticons/default/headbang.gif)
Running dual webers on a 2.0L '76
type2man
post Apr 27 2009, 02:14 PM
Check your idle jets, they probably are clogged. They are located on the outsides of the carbs close to where the fuel lines run into the carbs. Remove them and look at them closely to see if you have crap in there. If so, blow it out and drive it again.
Patrick
- Lo-Fi Version Time is now: 7th December 2025 - 04:42 AM
