> Tires spinning on the rim ..., How much of a problem is this?
post Apr 27 2009, 10:55 AM
Resident German
I always mark the race tires right where the valve stem is so i don't have to look for the stem when i'm in a hurry.
We put a new set of tires on the 911 one week ago at Tunderhill and this weekend i noticed that the markings had moved several inches in relationship to the valve stem.
So i marked the stem location again with a small dot and sure enough, after the first run session, the tires had moved again by several inches.
This only seems to happen in the rear, i'm guessing under hard acceleration when the tires are cold (first session in the morning).
Is this something that needs to be addressed or should i not worry about it?
(IMG:style_emoticons/default/confused24.gif) Andy
Krieger
post Apr 27 2009, 09:02 PM
I see two possible solutions to this problem, you need to unplug a couple of spark plug wires or use less lube.
- Lo-Fi Version Time is now: 19th July 2025 - 05:15 PM
