> a short steering coupler, for those with steering rack spacers
Wes V
post Apr 29 2009, 08:58 PM
I thought you guys out there with steering rack spacers would find this interesting.
If you space the rack higher, you should think about having a steering coupler (that rubber bisket) that is shorter.
That was the situation I was in and went looking for options. One is that on the "other" 914 site there is a guy that makes billet units that are the correct height. However I feel there are a couple reasons to retain something rubber.
After doing the math, I wanted a coupler that is 1 1/16" thick. (the stock one is about 1.33" high)
Now I've got to admit that what I came up with isn't totally an original idea. The site "nlaparts.com" sells a coupler for the 356C that's pretty much the same, but made to match the height of the original 356C coupler.
What I came up with is to use two early VW steering couplers. This gives a combined height of 1". They are only about $11.00 each.
The original 914 bolts are a little long, but could have been used. I purchased new 8mmx1.25x35 grade 8.8 (the original bolts are grade 8.8).
I've also ordered from Pelican new lock tabs (not shown in the photos).
So, here are the photos;
(IMG:http://www.performanceforum.com/wesvann/914a/SC1.JPG)
(IMG:http://www.performanceforum.com/wesvann/914a/SC2.JPG)
(IMG:http://www.performanceforum.com/wesvann/914a/SC3.JPG)
(IMG:http://www.performanceforum.com/wesvann/914a/SC4.JPG)
The only thing that would make it better is if somebody with a lath made up the steel collars to the correct length (1"). (Racer Chris has a lath! hint, hint)
Wes Vann
r_towle
post Apr 30 2009, 05:50 AM
Custom Member
Ever measure a hockey puck???
BTDT, it works like a charm...just drill out for the bolts, recycle the steel tubing (after you grind it down) and you get a 3 dollar spacer that fits tight.
Rich
Wes V
post Apr 30 2009, 08:09 AM
QUOTE(r_towle @ Apr 30 2009, 04:50 AM) *
Rich
This may sound like I'm being a smart ass (but in this case, I'm not);
No. I've never actually seen a hockey puck. I've heard of people using them for motor mounts and such. And yet, I've never really seen one.
Do they come in different hardness's?
Just another thing to research. Now I'm off to Big 5 Sporting Goods for Porsche parts.
Wes
brp986s
post Apr 30 2009, 09:12 AM
Doesn't the oem biscuit have a metal cylindrical perimeter for bracing? I'd be concerned about distortion or even stripping out the holes. Plus, possible movement between the 2 layers. Afterall, you're probably not running 155/80/15 tires - there will be alot of force acting on that thing.
Maybe a better solution would be to cast your own part using Flexane. Flexane is available in different hardnesses. I've read about Boxster owners using this stuff to make engine mounts.
- Lo-Fi Version Time is now: 2nd April 2026 - 12:37 PM
