I thought you guys out there with steering rack spacers would find this interesting.
If you space the rack higher, you should think about having a steering coupler (that rubber bisket) that is shorter.
That was the situation I was in and went looking for options. One is that on the "other" 914 site there is a guy that makes billet units that are the correct height. However I feel there are a couple reasons to retain something rubber.
After doing the math, I wanted a coupler that is 1 1/16" thick. (the stock one is about 1.33" high)
Now I've got to admit that what I came up with isn't totally an original idea. The site "nlaparts.com" sells a coupler for the 356C that's pretty much the same, but made to match the height of the original 356C coupler.
What I came up with is to use two early VW steering couplers. This gives a combined height of 1". They are only about $11.00 each.
The original 914 bolts are a little long, but could have been used. I purchased new 8mmx1.25x35 grade 8.8 (the original bolts are grade 8.8).
I've also ordered from Pelican new lock tabs (not shown in the photos).
So, here are the photos;
The only thing that would make it better is if somebody with a lath made up the steel collars to the correct length (1"). (Racer Chris has a lath! hint, hint)
Wes Vann
