echocanyons |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,107 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California ![]() ![]() ![]() |
Things were going great, the car is running good, got new tires and the car feels very balanced and solid. (IMG:style_emoticons/default/driving.gif)
In preparation for the WCR (and after getting new tires and replacing the rear suspension) I had a full alignment and corner balance done. I was supposed to pick it up today and I get a call that they can't bring the right rear into spec. So must be a bent trailing arm. I had previously noticed a bit more than usual neg camber to the passenger side trailing arm and am not to suprised, but still another freakin hangup. I haven't seen how far off spec it is but what would be an acceptable variance, without eating up tires. My alternative is yanking the T/A and swapping the bits from the bent arm to a spare that I have (I new my 2-3 tons of extra parts would come in handy (IMG:style_emoticons/default/rolleyes.gif) ). The other problem is that I am limited in time, I leave town for a conference this weekend and work until the WCR, how long of a job do you think swapping a trailing arm would be? Either way it's looking like the right rear will not be aligned professionally before the WCR. (IMG:style_emoticons/default/sad.gif) At least it wasn't all bad, the good news was it was within 3lbs of being perfectly balanced before he even touched it. (IMG:style_emoticons/default/biggrin.gif) |
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
If you have the tools and the parts you can do the swap in a few hours! But I agree with others that you should fix it later and do the "while I am in here" stuff at the same time! I had to do the same thing, bent trailing arm, and when I got the arm off the suspension ear was ovaled and needed to be welded up and re drilled!
Not my photos but you get the idea! Attached image(s) ![]() ![]() |
Lo-Fi Version | Time is now: 2nd July 2025 - 07:55 AM |
