TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,338 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
While pulling the motor from my friends car for a top end renewal, and removing the clutch cable I found a 13mm sockett under the adjustment nut. Someone
had put it there so they could adjust the clutch. I took it off and reattached the cable, but without it there was not enough adjustment. My first thought was a very stretched or wrong cable, but its the same length as a new one I have. Pulled clutch today. There is about an eighth inch of clutch left to the rivets. How thick are the faces on a new clutch? Would a worn out clutch cause the extreme adjustment problem? Thanks, |
Lo-Fi Version | Time is now: 9th July 2025 - 12:26 PM |
