pointless ignition timing, whats the best way |
level914 |
Feb 1 2004, 05:17 PM
Member Group: Members Posts: 68 Joined: 2-November 03 From: Sparks, Nv Member No.: 1,300 |
Again, sorry if this has come up before.
I was wondering if anything changes when doing the timing after installing a pointless ignition. Do I need to worry about dwell angle? Do I need a tachometer? Can I time it properly by just using top dead center, or do I need to also mark 27deg. BTDC? I have a 76 2.0. I have a timing light, and analyzer with dwell meter and tach. Do I need any other equiptment? I have printed out the pelican parts procedure. Is there a better way to do this. This is the first time I have ever timed a car. Thank you |
level914 |
Feb 1 2004, 06:37 PM
Ok, one last stupid question(hopefully)
My timing light has a positive clamp, negative clamp and a clamp that I believe goes aruond the #1 spark plug wire. It also has a setting dial on the back for degrees advance. How do I hook this up? And do I pull both hoses off the dizzy? Boy I feel stupid, first I admit I'm a Rams fan, second I don't even know how to hook up a timing light. |
Lo-Fi Version | Time is now: 8th June 2024 - 02:41 PM |
