Fuel tank questions...do I need these?, Charcoal cannister and expansion tank |
jcambo7 |
May 12 2009, 10:22 AM
Senior Member Group: Members Posts: 1,664 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest |
I have a 73 2.0 FI engine and I am wondering if I need the expansion take and/or charcoal cannister? If I can remove these than what do I do about the openings in my air intake for the charcoal cannister? And can someone please explain the purpose and what the charcoal cannister actually does please?
jcambo7 |
May 12 2009, 11:27 AM
So I can take the cannister off and not have a problem at all...but than what do I do about the openings for the charcoal cannisters hoses that connect to the air intake?
SirAndy |
May 12 2009, 11:33 AM
Resident German Group: Admin Posts: 41,677 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
So I can take the cannister off and not have a problem at all...but than what do I do about the openings for the charcoal cannisters hoses that connect to the air intake? You can. But you will have fuel smell inside the car every time you have more than a 3/4 tank of gas. - Plug the connection on the air filter and the one on the side of the fan housing. - Remove the lines behind the rocker. - Remove the charcoal canister. - Remove the expansion tank. - Route the small hose that goes to the expansion tank inside the large plastic overflow hose that goes from the filler neck down and outside the bottom of the car. - Get used to the smell of gas. (IMG:style_emoticons/default/bye1.gif) Andy |
jcambo7 |
May 12 2009, 11:45 AM
So I can take the cannister off and not have a problem at all...but than what do I do about the openings for the charcoal cannisters hoses that connect to the air intake? You can. But you will have fuel smell inside the car every time you have more than a 3/4 tank of gas. - Plug the connection on the air filter and the one on the side of the fan housing. - Remove the lines behind the rocker. - Remove the charcoal canister. - Remove the expansion tank. - Route the small hose that goes to the expansion tank inside the large plastic overflow hose that goes from the filler neck down and outside the bottom of the car. - Get used to the smell of gas. (IMG:style_emoticons/default/bye1.gif) Andy Thanks Andy Looks like I will just leave the cannister and expansion tank alone than... (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 04:45 PM |
