> my write-up on replacing the steering column bearings
Wes V
post May 12 2009, 08:22 PM
I just replaced the bearings within the steering column assembly and thought you all would like the write-up. (lots of photos)
my web site page
It was easy and straight forward.
Now the steering wheel doesn't flop around!
Wes Vann
charliew
post May 12 2009, 09:28 PM
Good write up, it shows lots of parts not normally seen in the column. There are already some write ups on doing this. If the bottom bearing is ok, it probably will be, it's a lot better bearing than the top one and it's also a sealed bearing where the top one is not. You can really just take the upper housing off of the shaft leaving the shaft and lower housing in the car. The nylon sleeve is the hard part to get it seems it's only a porsche part but a vw metal sleeve and bearing is readily available and will work. It really should be put in with the lip down as you did on either type. Also it's real easy to get some of the wires out of there little channels so watch them closely, it will hang up not going all the way back together if the wires get out of place. There is also a little insulator inbetween the contacts for the highbeam switch to check that it doesn't get broken off. I also have a 72 super beetle and it looks like the turn signal assembly may be the same part as my 75 914 switch. Also some people have said that the bearing was not snug in the aluminum housing and it needed some shimming.
Wes V   my write-up on replacing the steering column bearings   May 12 2009, 08:22 PM
teddyf1   Nicely done! When I make this repair I'll...   May 12 2009, 08:50 PM
Joe Owensby   Good write up. Thanks, I also liked the other ...   May 12 2009, 09:03 PM
charliew   Good write up, it shows lots of parts not normally...   May 12 2009, 09:28 PM
Wes V   Charliew; When I was doing research, I kept heari...   May 13 2009, 05:55 AM
zonedoubt   I don't remember seeing the smaller external r...   May 13 2009, 10:27 AM
Wes V   I don't remember seeing the smaller external ...   May 13 2009, 11:43 AM
SLITS   The "quick fix" is the plastic sleeve an...   May 13 2009, 10:35 AM
Wes V   The "quick fix" is the plastic sleeve a...   May 13 2009, 11:46 AM
andys   Wes, Nice write up. I found my problem to be in ...   May 13 2009, 12:28 PM
Wes V   Wes, Nice write up. I found my problem to be in...   May 13 2009, 01:16 PM
andys   I've heard of people using a couple layers o...   May 13 2009, 01:45 PM
Bleyseng   Thanks for a write up as I need to do this repair ...   May 14 2009, 09:15 AM
charliew   I got into the bearing deal actually working on a ...   May 14 2009, 10:38 AM
Wes V   Thanks for posting up that information. About cos...   May 14 2009, 05:31 PM
Gint   Nice write up. FYI, I found a duplicate thread ...   May 15 2009, 08:48 AM
Wes V   FYI, I found a duplicate thread with 0 relies. I...   May 15 2009, 12:44 PM
Gint   Oops... gimme a minute. And I can put the entire ...   May 15 2009, 10:42 PM
Wes V   Oops... gimme a minute. And I can put the entire...   May 16 2009, 07:48 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:50 AM
