> Engine is dropped, was easier the second time around
VaccaRabite
post May 10 2009, 08:17 PM
En Garde!
Engine is down to rebuild after the low oil episode at Hershey. I'm probably don't need to rebuild it, but I am adding a new cam and I want to do some things that I did not know about when I built it the first time in 2007.
I pulled the engine out of my car this afternoon after trimming the hedges and killing all the weeds I could find to kill. I had removed the exhaust and CV bolts the other day. Drop went REAL easy. I used Foley's engine plate on a jack, and it was a 1 hour job (including removing the CVs, carbs, wires, etc). Did it all by my onesy while smoking a cigar.
Tin is off, engine and tranny are still attached. I'm going to cut the grass again tomorrow and then remove the transmission. maybe get the eads off too, depending on how much energy I have.
My goal is to have the engine stripped and back together in a month. I need to find out why the pump was not making pressure, add the cam, and remeasure all my bearing tolerances. I also want to change the distributor drive gear. The one in th engine now is a little worn. I have a very nicer one that i am going to put on the crank. When we were timing the engine a few months ago, the timing line was dancing around a little bit, and I think it was due to the drive gear wearing.
I am also going to pull all the galley plugs (the are already tapped, so that will be easy) and make sure they are not blocked or sludge filled.
I also want to take the craptastic aftermarket oil dipstick tube off and put on a proper 914 dipstick tube. That was a big part of my failure - trusting the aftermarket dipstick.
So, any way, a few pics of the drop.
(IMG:http://farm4.static.flickr.com/3599/3519841329_7df0721de1.jpg)
Came down so easy. I did not even have to remove the rear valence. Way less complicated then with the FI on.
Here is a mystery.
One of the things that I want to do is see if I can button up any leaks. It figures that I got the last known leak the week before I decide to take down my engine. But there was one more elusive drip.
(IMG:http://farm4.static.flickr.com/3637/3520656296_c743c979c0.jpg)
Do you see the oil under those two studs? How the heck does oil get there? There is also a little on the ridge right under the serial number.
Here is another pic of the area.
(IMG:http://farm4.static.flickr.com/3647/3519842797_cd8543ca4b.jpg)
So, but the end of the week, I hope to have the case split and cleaned and measured over the weekend. Aggressive schedule, but I only have 2 weeks of no classes until summer classes start again. Then the next time I will have to work with my motor is when I take off a week in June for my birthday. I'm hoping to have this sucker done by then! In june, I want to get my truck on the road.
Zach
type11969
post May 13 2009, 08:36 AM
damn, and after all that work figuring out how to safety wire those CV bolts . . .
Good luck with the work, I'd offer to help but my quarter (drexel is on the quarter system which is stupid) is drawing to a close and you know how that is. I'm real curious to know what the issue is with your oil pressure. As for sealing it, Jake does offer some nice sealants through his store which he allegedly has good luck with . . . I'll let you know in a few weeks how well they work.
VaccaRabite
post May 13 2009, 09:50 AM
En Garde!
QUOTE(type11969 @ May 13 2009, 09:36 AM) *
From what I have been reading, my issue may be as simple as putting in a paper gasket where one should not have been. I used a paper gasket between the pump and the plate, and it seems like I was not supposed to have used a gasket there, just a little sealant.
I won't know for sure though until I get things apart and back together again.
I'd really like to be able to fix the dipstick tube so I can use that nice Mainley dipstick/temp gauge I bought. But, if its too much of a bitch to pull the tube and put in a new one, I now have the correct oil level market on the aftermarket dipstick.
Zach
Vacca Rabite   Engine is dropped   May 10 2009, 08:17 PM
statesblue   So where is Dallastown Pa.????   May 10 2009, 08:47 PM
Vacca Rabite   So where is Dallastown Pa.???? Between York, PA...   May 11 2009, 06:46 AM
904svo   So where is Dallastown Pa.???? Between York, P...   May 11 2009, 07:23 AM
r_towle   Dude, Your oil filler tower is leaking. Look at th...   May 10 2009, 09:19 PM
Vacca Rabite   What is a crank vent? I have to assume this is di...   May 11 2009, 08:27 AM
904svo   What is a crank vent? I have to assume this is d...   May 11 2009, 09:19 AM
Vacca Rabite   Okay. I had lines that ran from the head vents to...   May 11 2009, 09:33 AM
904svo   Okay. I had lines that ran from the head vents t...   May 11 2009, 03:47 PM
McMark   The EMPI breather box lid has vents to atmosphere....   May 11 2009, 04:08 PM
Vacca Rabite   The EMPI breather box lid has vents to atmosphere...   May 13 2009, 07:29 AM
r_towle   Zach, Lets see the PVC valve...with carbs there sh...   May 11 2009, 04:24 PM
charliew   Zach your truck is in the july 4wheel and off road...   May 12 2009, 11:24 PM
type11969   damn, and after all that work figuring out how to ...   May 13 2009, 08:36 AM
Vacca Rabite   damn, and after all that work figuring out how to...   May 13 2009, 09:50 AM
type11969   Dunno, pretty sure the thin red gasket always goes...   May 13 2009, 10:04 AM
hcdmueller   After building one of Jake's 2056 kits I can s...   May 13 2009, 03:08 PM
Vacca Rabite   I got the oil dipstick tube off by tapping the epo...   May 13 2009, 08:34 PM
- Lo-Fi Version Time is now: 16th June 2024 - 09:40 PM
