| Wes V |
May 12 2009, 08:22 PM
Member ![]() ![]() Group: Members Posts: 482 Joined: 11-October 07 From: Los angeles Member No.: 8,211 |
I just replaced the bearings within the steering column assembly and thought you all would like the write-up. (lots of photos)
my web site page It was easy and straight forward. Now the steering wheel doesn't flop around! Wes Vann |
| andys |
May 13 2009, 12:28 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None
Wes,
Nice write up. I found my problem to be in the aluminum (die cast) housing. The outside of the bearing wore the aluminum bearing bore just enough to create some slop in the steering wheel. I saw no way to fix this short of boring a larger hole and pressing in a bushing, but that gets complicated with the snap ring groove, limited available material to machine, etc. Andys |
| Wes V |
May 13 2009, 01:16 PM
Wes, Nice write up. I found my problem to be in the aluminum (die cast) housing. The outside of the bearing wore the aluminum bearing bore just enough to create some slop in the steering wheel. I saw no way to fix this short of boring a larger hole and pressing in a bushing, but that gets complicated with the snap ring groove, limited available material to machine, etc. Andys Thanks for the comment. I've heard of people using a couple layers of tin foil as shims. Unless the housing is cracked, you could try that. Another thought would be a thin coat of JB weld. Of course, ever servicing it again would be a problem. Wes |
Wes V my write-up on replacing the steering column bearings May 12 2009, 08:22 PM
teddyf1 Nicely done! When I make this repair I'll... May 12 2009, 08:50 PM
Joe Owensby Good write up. Thanks,
I also liked the other ... May 12 2009, 09:03 PM
charliew Good write up, it shows lots of parts not normally... May 12 2009, 09:28 PM
Wes V Charliew;
When I was doing research, I kept heari... May 13 2009, 05:55 AM
zonedoubt I don't remember seeing the smaller external r... May 13 2009, 10:27 AM
Wes V
I don't remember seeing the smaller external ... May 13 2009, 11:43 AM
SLITS The "quick fix" is the plastic sleeve an... May 13 2009, 10:35 AM
Wes V
The "quick fix" is the plastic sleeve a... May 13 2009, 11:46 AM
andys
I've heard of people using a couple layers o... May 13 2009, 01:45 PM
Bleyseng Thanks for a write up as I need to do this repair ... May 14 2009, 09:15 AM
charliew I got into the bearing deal actually working on a ... May 14 2009, 10:38 AM
Wes V Thanks for posting up that information.
About cos... May 14 2009, 05:31 PM
Gint Nice write up.
FYI, I found a duplicate thread ... May 15 2009, 08:48 AM
Wes V
FYI, I found a duplicate thread with 0 relies. I... May 15 2009, 12:44 PM
Gint Oops... gimme a minute.
And I can put the entire ... May 15 2009, 10:42 PM
Wes V
And I can put the entire... May 16 2009, 07:48 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:14 AM |
