Transmission Seal and Pressure, Lots of pressure again the seal? |
Cire |
May 14 2009, 10:46 PM
Member Group: Members Posts: 279 Joined: 12-March 09 From: Tucson, Arizona Member No.: 10,155 Region Association: None |
I have those little nicks in my seal surface for the tranny. I put a new seal in and did all the clean up everyone recomended. My question is, how much oil is going to be hitting the back of the seal? If it leaked are we talking 2 or 3 drops or are we talking 2 quarts a drive? Just trying to understand the impact, or possible impact.
Thanks. Eric |
Bleyseng |
May 15 2009, 06:00 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
also affecting the seals sealing is the play in the shaft due to wear in the bearings. The ones in the tranny and the one in the flywheel, if those don't support the shaft so there is little movement then lots of 90wt oil flys out.
Cire |
May 15 2009, 06:20 AM
also affecting the seals sealing is the play in the shaft due to wear in the bearings. The ones in the tranny and the one in the flywheel, if those don't support the shaft so there is little movement then lots of 90wt oil flys out. So I had a thought about testing the seal. My tranny is out of the car and on my bench. If I fill it with oil and then tip it up so that the level line on the oil is higher than the seal (seal fully submerged) and it didnt leak I would be safe? I guess thats why I was wondering about pressure inside the tranny. Is there much build up? It has a direct vent tube and I would think there wouldnt be much pushing that oil out that seal. Another thought is how much of that shaft is in actual oil? If you step on the brakes all the oil runs to the front of the engine (the seal). = ) Just trying to save myself some work and test the seal ahead of time. How much could leak? Still driveable? Add a quart monthly? LOL Eric |
Lo-Fi Version | Time is now: 8th June 2024 - 09:09 AM |
