Help! Shift Coupler removal |
Van914 |
May 15 2009, 07:34 AM
Van914 Group: Members Posts: 698 Joined: 5-January 03 From: Cincinnati, Ohio Member No.: 90 Region Association: Upper MidWest |
Help me! Before I get the BFH out (IMG:style_emoticons/default/smash.gif)
How do you get the shift coupler off the rear shift rod? Hammer and punch or press? Thanks Van |
Tom |
May 15 2009, 07:56 AM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
If you are talking about the front coupler on the rear shift rod, then a proper sized socket under the coupler and a gentle tap or three with a hammer and punch should get the pin out. I have heard of some being pretty difficult and others may chime in here, but, the coupler is aluminum, so guess what will break first.
Good luck. I did a thread on here a few years ago about making some home made bushing that you can search and find if you have an interest. I found new stock bushings a little loose due to wear of the rod and coupler. Tom |
Lo-Fi Version | Time is now: 4th June 2024 - 12:48 PM |
