| Wes V |
May 14 2009, 10:16 PM
Member ![]() ![]() Group: Members Posts: 482 Joined: 11-October 07 From: Los angeles Member No.: 8,211 |
Well, here is a link to my latest write-up where I show how to rebuild a steering rack and add a turbo tie rod kit.
My Webpage I know that there is an equal write-up on the Pelican board. Let me know what you all think. It's long and there are a lot of photos (god bless digital cameras) Wes V |
| JFJ914 |
May 16 2009, 09:23 AM
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States
Nice, but two criticisms:
1. Why didn't you use the thick steering stop/spacer supplied with the kit? Porsche used it for a reason! It sets the tie rod adj at mid point on the threads. You have to adj the rods with less thread engagement with your washer. 2. Why cobble the rubber coupler? The real part is avaliable at the dealer. |
Wes V my write-up on rebuilding a rack and adding turbo tie rod end May 14 2009, 10:16 PM
Gint :bump: May 15 2009, 10:43 PM
charliew Ok nice write up. I have a question. If you use a ... May 15 2009, 11:44 PM
Wes V
Ok nice write up. I have a question. If you use a... May 16 2009, 05:55 AM
Wes V Dang, dang, dang;
When I did the turbo tie rod in... May 16 2009, 08:02 AM
Wes V
1. Why didn't you ... May 16 2009, 01:22 PM
Bartlett 914 Nice write up.
If someone is doing this and is n... May 16 2009, 10:29 AM
Wes V
If someone is doing this and is not replacing th... May 16 2009, 01:09 PM
Bartlett 914
If someone is doing this and is not replacing t... May 16 2009, 06:08 PM
Wes V That does make sense and I understand what you are... May 17 2009, 09:33 AM
Wes V I've got a request;
When I installed the tie... May 17 2009, 09:38 AM
Bartlett 914
That does make sense and I understand what you ar... May 17 2009, 09:59 AM
John Jentz 32mm, less than 5mm thick. May 17 2009, 01:17 PM
Wes V
Thanks! I didn... May 17 2009, 06:11 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:56 AM |
