| Wes V |
May 14 2009, 10:16 PM
Member ![]() ![]() Group: Members Posts: 482 Joined: 11-October 07 From: Los angeles Member No.: 8,211 |
Well, here is a link to my latest write-up where I show how to rebuild a steering rack and add a turbo tie rod kit.
My Webpage I know that there is an equal write-up on the Pelican board. Let me know what you all think. It's long and there are a lot of photos (god bless digital cameras) Wes V |
| Bartlett 914 |
May 16 2009, 10:29 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Nice write up.
If someone is doing this and is not replacing the needle bearing, I would make sure to measure the needles before assembly. I believe the diameters are not all the same! Half of them will be a bit smaller. Maybe only a thousandth or two. If I am correct, then the needles must be installed in an alternating state. This reduces the rotational resistance. Failure to do this will create a stiffer bearing that will fail prematurely. |
Wes V my write-up on rebuilding a rack and adding turbo tie rod end May 14 2009, 10:16 PM
Gint :bump: May 15 2009, 10:43 PM
charliew Ok nice write up. I have a question. If you use a ... May 15 2009, 11:44 PM
Wes V
Ok nice write up. I have a question. If you use a... May 16 2009, 05:55 AM
Wes V Dang, dang, dang;
When I did the turbo tie rod in... May 16 2009, 08:02 AM
John Jentz Nice, but two criticisms:
1. Why didn't you u... May 16 2009, 09:23 AM
Wes V
1. Why didn't you ... May 16 2009, 01:22 PM
Wes V
If someone is doing this and is not replacing th... May 16 2009, 01:09 PM
Bartlett 914
If someone is doing this and is not replacing t... May 16 2009, 06:08 PM
Wes V That does make sense and I understand what you are... May 17 2009, 09:33 AM
Wes V I've got a request;
When I installed the tie... May 17 2009, 09:38 AM
Bartlett 914
That does make sense and I understand what you ar... May 17 2009, 09:59 AM
John Jentz 32mm, less than 5mm thick. May 17 2009, 01:17 PM
Wes V
Thanks! I didn... May 17 2009, 06:11 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:56 AM |
