| Bruce Allert |
Feb 1 2004, 11:24 PM
Hellions asleep ![]() ![]() ![]() ![]() Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
Ya! I get in this morning (a wee bit coolish out) and take it outta gear & start it. I get a slight movement. Starter is pulled down a bit like the battery is low. Still, the car outta gear but I push in the clutch for the 2nd try of starting it. It starts and I let out the clutch (still outta gear) & the engine drags down with a slight movement forward. What is happening here? This doesnt make sense to me. If it's outta gear there shouldn't be any way for forward propulsion.
........b |
| Dave_Darling |
Feb 2 2004, 04:05 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,338 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
I've even seen the effect on a warm summer's day... The car was idling on a lift, both rear wheels in the air. One of them was turning slowly. If you grabbed it, it stopped easily, but the other one slowly started to turn. If you grabbed both, they would stop. When you let go, the one would eventually start to turn again. It was quite weird, but not abnormal.
--DD |
Bruce Allert Start Car (out of gear) Car Moves Feb 1 2004, 11:24 PM
Rob Ways Check your shifter connection at the firewall. You... Feb 1 2004, 11:33 PM
Bruce Allert You mean you can still be in gear a little bit? I ... Feb 1 2004, 11:45 PM
Jake Raby sometimes when gear oil is cold it has enough visc... Feb 2 2004, 12:31 AM
redshift You have a rare automatic! Use F-type fluid... Feb 2 2004, 12:34 AM
Rob Ways Sorry I misread your post.... so your car lurches ... Feb 2 2004, 12:44 AM
Eric_Shea Growing up with bugs and teeners in Michigan this ... Feb 2 2004, 02:16 PM
airsix You can also see this effect on the hiway. You wil... Feb 2 2004, 05:08 PM
Bruce Allert ![]() ![]() |
Lo-Fi Version | Time is now: 29th April 2026 - 02:58 PM |
