Exhaust shield, should i toss it |
Tman914 |
May 21 2009, 06:29 PM
Member Group: Members Posts: 136 Joined: 9-December 04 From: "Livermore, Ca" Member No.: 3,247 Region Association: Central California |
My 914 rear trunk area was cut out and replace with new tin I was installing
a rear OEM sway bar and it was hitting the heat shield for the muffiler in order to get the sway bar in I had to remove it do I need to put it back in I'm running a Sebring Exhaust system |
SirAndy |
May 21 2009, 08:47 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
My 914 rear trunk area was cut out and replace with new tin I was installing a rear OEM sway bar and it was hitting the heat shield for the muffiler in order to get the sway bar in I had to remove it do I need to put it back in I'm running a Sebring Exhaust system Actually, there should be no need to remove the heat shield to install the bar. You have to slide the bar in from one side between the heatshield and the trunk floor. It's a bit tricky at first, but it'll fit in there without any cutting. (IMG:style_emoticons/default/shades.gif) Andy |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:08 PM |
