QUOTE(Tman914 @ May 21 2009, 05:29 PM)
My 914 rear trunk area was cut out and replace with new tin I was installing
a rear OEM sway bar and it was hitting the heat shield for the muffiler in order
to get the sway bar in I had to remove it do I need to put it back in
I'm running a Sebring Exhaust system
Actually, there should be no need to remove the heat shield to install the bar.
You have to slide the bar in from one side between the heatshield and the trunk floor. It's a bit tricky at first, but it'll fit in there without any cutting.
Andy
