Exhaust shield, should i toss it |
Tman914 |
May 21 2009, 06:29 PM
Member Group: Members Posts: 136 Joined: 9-December 04 From: "Livermore, Ca" Member No.: 3,247 Region Association: Central California |
My 914 rear trunk area was cut out and replace with new tin I was installing
a rear OEM sway bar and it was hitting the heat shield for the muffiler in order to get the sway bar in I had to remove it do I need to put it back in I'm running a Sebring Exhaust system |
JoeSharp |
May 21 2009, 06:32 PM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
You can warm food in the rear trunk with the shield inplace. It can get up to 125 in there.
Tman914 |
May 21 2009, 06:37 PM
ok so put back on I seen other 914's with out I just asking
PanelBilly |
May 21 2009, 07:21 PM
914 Guru Group: Members Posts: 5,804 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I took mine off years ago and haven't had any problem with the trunk getting too hot
Then again, I don't have an engine in the car..... |
Tman914 |
May 21 2009, 07:33 PM
lololoololool ok thanks that was funny
Bill D |
May 21 2009, 07:59 PM
Member Group: Members Posts: 66 Joined: 1-August 06 From: North Carolina Member No.: 6,558 |
why not wrap the muffler in heat wrap?
GeorgeRud |
May 21 2009, 08:30 PM
Remember, these cars were built for a price. If they could have left the shield off, they would have! I'd recommend replacing it.
May 21 2009, 08:47 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
My 914 rear trunk area was cut out and replace with new tin I was installing a rear OEM sway bar and it was hitting the heat shield for the muffiler in order to get the sway bar in I had to remove it do I need to put it back in I'm running a Sebring Exhaust system Actually, there should be no need to remove the heat shield to install the bar. You have to slide the bar in from one side between the heatshield and the trunk floor. It's a bit tricky at first, but it'll fit in there without any cutting. (IMG:style_emoticons/default/shades.gif) Andy |
Tman914 |
May 22 2009, 12:29 AM
thanks guys
Lo-Fi Version | Time is now: 10th May 2024 - 04:04 AM |
