r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
OK,
I am down to the core motor, a 2.0 liter. I still cannot turn the crank with a loooonnngggg wrench. I assume since this was field stored in the North East for over ten years that we have a rust issue here. I know you CA guys are not used to this. My question is this...How would one go about freeing up the pistons from the cylinders if in fact that is where it has a rust problem??? Is there a special tool out there, kinda like a gear puller, but larger that will pull the cylinder off the piston??? Once that is done, the rest will come apart even if there is rust... Rich |
r_towle |
I have BTDT before with Type 1 engines, just hoping someone might have invented a nicer tool for the process ....
hint hint hint... rich |
Lo-Fi Version | Time is now: 2nd July 2025 - 07:58 PM |
