| Gint |
Jun 4 2009, 04:39 PM
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,106 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I've thought about doing a Megasquirt for a while now to replace my carbs. I have a Mallory that works great, so to keep the initial cost down as well as keep it simple, I want to do fuel only, but have an upgrade path available for ignition later. Ideally if this could be done for under $500 that would be fantastic.
So... What is the easiest, cheapest, most simple solution for induction parts? Throttle bodies, injectors, TPS, etc...? Which MS unit has the flexibility to do fuel now and ignotion later without starting all over again with a different ECU? Engine is a 2056 that is built on a 1.8 case and heads with a 2.0 crank, rods and P/Cs. Currently running dual Weber 40 IDFs. (IMG:style_emoticons/default/idea.gif) (my own note: 40 IDF 70 9A, Italy) |
| lotus_65 |
Jun 5 2009, 06:03 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,609 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
what cam are you running?
i've been thinking about this too... |
Gint Cheap, simple, non-factory FI solution, parts, etc... Jun 4 2009, 04:39 PM
SLITS Just buy the TEC 2 Engine Management System I have... Jun 4 2009, 06:03 PM
Gint Just buy the TEC 2 Engine Management System I have... Jun 4 2009, 06:42 PM
SLITS
Just buy the TEC 2 Engine Management System I hav... Jun 4 2009, 08:20 PM
Gint [quote name='Gint' post='1176738' date='Jun 4 2009... Jun 4 2009, 09:25 PM
tat2dphreak this is something I've thought about doing lat... Jun 4 2009, 07:47 PM
orcadigital I am interested too, would love to lose the single... Jun 4 2009, 07:55 PM
rick 918-S This is an important subject as our injection stuf... Jun 4 2009, 08:23 PM
banger Megasquirt is pretty cheap and easy, and you can u... Jun 4 2009, 10:35 PM
toon1 No idea exactly what you're pimping though. C... Jun 4 2009, 10:36 PM
McMark My thoughts:
The ECU setup is going to eat up most... Jun 4 2009, 10:43 PM
banger Actually with the Megasquirt, the TPS isnt even ne... Jun 4 2009, 10:55 PM
Rotary'14 Avoid the hassel of building it yourself,, go with... Jun 4 2009, 11:35 PM
charliew While you are shopping keep in mind that the coil ... Jun 5 2009, 12:02 AM
rick 918-S I like McMarks test engine idea. Hey, So am I off ... Jun 5 2009, 12:24 AM
sww914 Junkyard Subaru parts look interesting... Jun 5 2009, 12:27 AM
banger Most modern fuel injection systems are tuned to th... Jun 5 2009, 02:17 AM
rick 918-S
Most modern fuel injection systems are tuned to t... Jun 5 2009, 10:02 AM
Gint Megasquirt is pretty cheap and easy, and you can u... Jun 5 2009, 08:22 AM
edwin if you have webber manifold then bmw bike throttle... Jun 5 2009, 06:46 AM
Gary Hey Edwin - do you have the center-to-center spaci... Jun 5 2009, 08:19 AM
rhodyguy vw (jetta, golf, sirroco, etc) CIS. ed morrow used... Jun 5 2009, 08:47 AM
toon1
Megasquirt is pretty cheap and easy, and you can ... Jun 5 2009, 09:04 AM
Gint Again, your carbs can be used as TB's, change ... Jun 5 2009, 09:11 AM
tat2dphreak not necessarily... the 1.8 heads have the same bol... Jun 5 2009, 09:40 AM
Gint not necessarily... the 1.8 heads have the same bol... Jun 5 2009, 10:33 AM
tat2dphreak
not necessarily... the 1.8 heads have the same bo... Jun 5 2009, 10:56 AM
biosurfer1 Wayne, you mean something like this?
http://www.9... Jun 5 2009, 09:49 AM
tat2dphreak
http://www.... Jun 5 2009, 10:54 AM
turboman808 megasquirt with some motorcycle throttlebodies Jun 5 2009, 10:40 AM
SirAndy :D http://www.914world.com/bbs2/index.php?showtopi... Jun 5 2009, 10:41 AM
Gint Btw, i also have a spare set of 40 IDF dual webers... Jun 5 2009, 10:51 AM
Gint They're not carbs though. They're expensi... Jun 5 2009, 11:00 AM
rick 918-S Just spoke with a mechanic friend. He has a comple... Jun 5 2009, 11:27 AM
banger The problem with using watercooled stuff is exactl... Jun 5 2009, 03:55 PM
nein14 CIS injection from a VW GTI w/ Bus runners , plenu... Jun 5 2009, 11:44 AM
Gint Keep 'em comin gang! This is great. Jun 5 2009, 11:51 AM
My ... Jun 5 2009, 12:28 PM
rick 918-S
[quote name='Gint' post='1177009' date='Jun 5 200... Jun 5 2009, 12:38 PM
JWest I've got a couple of Megasquirt 1 kits. You c... Jun 5 2009, 04:44 PM
Gint That would be awesome James. I can't take it ... Jun 5 2009, 05:10 PM
wobbletop Sorry to thread hi-jack... I'm a newb, but I h... Jun 5 2009, 10:32 PM
r_towle
Sorry to thread hi-jack... I'm a newb, but I ... Jun 7 2009, 10:06 AM
lotus_65
Sorry to thread hi-jack... I'm a newb, but I... Jun 7 2009, 10:38 AM
zymurgist You might want to start a new thread on that topic... Jun 6 2009, 07:26 AM
Gint :agree: A little more specialized and I'd li... Jun 6 2009, 08:24 AM
DNHunt I've now worked with MS1, MS2 and SDS. I'v... Jun 6 2009, 10:00 AM
Cevan
If I wanted cheap, I'd find a 2 liter intake,... Jun 7 2009, 11:16 AM
Gint Thanks Dave. Harness huh... :idea: I've hear... Jun 6 2009, 10:42 PM
sww914 Thanks for starting a great thread. Long overdue i... Jun 6 2009, 10:51 PM
Phoenix-MN How about the MicroSquirt system
http://www.diyau... Jun 7 2009, 08:29 AM
Gint So, I'm thinking that the way to do this might... Jun 8 2009, 08:01 AM
puff adder I found this company while looking for ITB's f... Jun 7 2009, 10:44 AM
crash914 I have also ran mine as a piggy back system on the... Jun 7 2009, 11:05 AM
charliew It's the programming for the different motor c... Jun 7 2009, 11:26 AM
Gint How about the MicroSquirt system
http://www.diyau... Jun 8 2009, 08:02 AM
underthetire Think it's pretty much the same as the MS2. Ju... Jun 8 2009, 09:41 AM
jd74914 I've used Microsquirt. Its not too difficult t... Jun 8 2009, 11:22 AM
McMark The system I have been posting about uses MicroSqu... Jun 8 2009, 12:44 PM
Gint The system I have been posting about uses MicroSqu... Jun 8 2009, 06:58 PM
r_towle
[quote name='McMark' post='1178034' date='Jun 8 2... Jun 8 2009, 07:14 PM
McMark The motor runs, but I need to get a stock CHT sens... Jun 8 2009, 07:11 PM
Gint The motor runs, but I need to get a stock CHT sens... Jun 8 2009, 07:20 PM
McMark If it ain't D-Jet, it ain't MPS. ;) Thin... Jun 8 2009, 07:34 PM
r_towle
MAF sensors as well which are a completely differ... Jun 8 2009, 07:40 PM
Gint If it ain't D-Jet, it ain't MPS. ;) Thin... Jun 9 2009, 07:25 AM
Rotary'14
[quote name='McMark' post='1178238' date='Jun 8 2... Jun 9 2009, 01:48 PM
Gint Hi Gint,,
MegaSquirts have an on board MAP sensor ... Jun 9 2009, 05:36 PM
jhadler
As for the MegaSquirt's onboard MAP sensor, h... Jun 9 2009, 05:46 PM
sww914 I'd argue that you need to measure temperature... Jun 8 2009, 08:04 PM
tat2dphreak
I'd argue that you need to measure temperatur... Jun 9 2009, 08:15 AM
McMark Before I start this post, a definition. When I sa... Jun 9 2009, 12:31 PM
kwales There are other ways of measiuring airflow..
Don... Jun 9 2009, 01:49 PM
McMark I actually greatly prefer the remote MAP sensor of... Jun 9 2009, 03:42 PM
jmill Great topic and info.
:popcorn: Jun 9 2009, 04:53 PM
r_towle Gint, contact DNHunt and see if he will sell his o... Jun 9 2009, 05:25 PM
Gint Spell it out for me. Does a vacuum line have to ... Jun 9 2009, 05:51 PM
jhadler
Spell it out for me. Does a vacuum line have to... Jun 9 2009, 06:03 PM
r_towle
Spell it out for me. Does a vacuum line have t... Jun 9 2009, 06:35 PM
Rick_Eberle
[quote name='jhadler' post='1178707' date='Jun 9 ... Jun 9 2009, 06:55 PM
Rotary'14
Spell it out for me. Does a vacuum line have t... Jun 9 2009, 08:03 PM
Gint Excellent... thanks!
Wait till you see what... Jun 9 2009, 08:27 PM
McMark I also like the MicroSquirt because it's seale... Jun 10 2009, 02:58 AM
Gint New questions generated from yesterday's dicsu... Jun 10 2009, 07:08 AM
jhadler
New questions generated from yesterday's dics... Jun 10 2009, 12:02 PM
Gint Gint,
I think a whole lot of questions can be ans... Jun 10 2009, 02:35 PM
McMark You can see the little black vacuum port in the fo... Jun 10 2009, 01:07 PM
McMark
:lol2: Jeff Keyzer was who pushed me to go crank ... Jun 10 2009, 02:41 PM
Gint :lol2: Jeff Keyzer was who pushed me to go crank f... Jun 10 2009, 02:47 PM
jkeyzer Mark summoned me so here's my $0.02!
... Jun 10 2009, 03:16 PM
Gint Mark summoned me so here's my $0.02!
... Jun 10 2009, 04:04 PM
jmill I'm loving this thread. :Qarl:
The only rea... Jun 10 2009, 03:27 PM
jhadler
The only re... Jun 10 2009, 03:45 PM
underthetire Again, forget the MS1. Go MS2. If you plan on usin... Jun 10 2009, 03:37 PM
Rotary'14
Again, forget the MS1. Go MS2. If you plan on usi... Jun 10 2009, 04:14 PM
jkeyzer You can do it with Megasquirt, and people do. The... Jun 10 2009, 03:40 PM
underthetire Multiple throttle bodies no problem, just one TPS ... Jun 10 2009, 03:44 PM
jkeyzer Gint - Yup, that's the same setup that I have... Jun 10 2009, 04:05 PM
Gint :cheer: Jun 10 2009, 04:07 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:02 AM |
