Best spark plugs for 1.7 ? |
orange73 |
Jun 8 2009, 10:25 AM
orange 72 Group: Members Posts: 14 Joined: 11-May 09 From: Homer Glen IL. Member No.: 10,355 Region Association: Upper MidWest |
I need new plugs for the 72 1.7 eng. , whats the plugs most people have best luck with ? There are Bosch super RO 971 in now.
Cap'n Krusty |
Jun 8 2009, 11:08 AM
That's not a part number. The number is stamped into the metal, not printed on the ceramic. You should be using NGK B6ES (7432) or Bosch W7CC (7998). With carbs, you should probably run one heat range hotter. The Cap'n
orange73 |
Jun 8 2009, 03:51 PM
That's not a part number. The number is stamped into the metal, not printed on the ceramic. You should be using NGK B6ES (7432) or Bosch W7CC (7998). With carbs, you should probably run one heat range hotter. The Cap'n Thanks and yes the stamped number is w7cc, I do have dual Webers carbs, so how do i know one heat range hotter ? |
Lo-Fi Version | Time is now: 11th June 2024 - 09:34 AM |
