SS fuel line install questions |
bobhasissues |
Jun 10 2009, 09:30 AM
seemingly endless issues with my 914 Group: Members Posts: 218 Joined: 13-February 07 From: Chicagoland Member No.: 7,532 Region Association: None |
Preparing to install the CFR 3/8" SS fuel line in my carbed '73. I will only be installing the single line for the carbs, so what is the best way to terminate the return line nipple coming off the gas tank? Do I tie both nipples together with a "Y" or "T" connector, or is it best to just block off the return nipple? Either way, what hardware works best?
topatrout914 |
Jun 10 2009, 12:57 PM
Trout Group: Members Posts: 64 Joined: 13-October 06 From: Thomasville, NC Member No.: 7,034 Region Association: South East States |
I cut the side out of an empty qurt oil container, its made from hdpe which resists hydrocarbons. remove the large nut that retains the nipple and use the backside as a template and cut a piece of hdpe and put it between the tank and nipple and tighten the nut back on. It has been OK for the last two years with no leak.
Lo-Fi Version | Time is now: 2nd June 2024 - 04:30 PM |
