todays it the engines going in ! |
rfuerst911sc |
Jun 13 2009, 04:58 AM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
With the help of this forum and 2 1/2 years of work today my GT clone gets her motivation installed. I nervously woke up at 4:30 this morning as I couldn't sleep any longer (IMG:style_emoticons/default/smile.gif) . I went out to the garage to give her a look and she's ready (IMG:style_emoticons/default/biggrin.gif) . To back up a little on a whim I purchased a 1975 rolling chassis in December of 2006 sight unseen. I was able to view pictures but that was it. Turns out it was a good gamble as she turned out to be rust free as it was off the road and in a local garage since 1991. Purchased her for $900.00 with lots of extra parts. My goal was to turn her into a GT clone or since I have learned it really is a M471 clone. I knew I wanted a six and in 2008 I found a 1978 911 3.0 motor in N.C. that I purchased. Induction is 40mm Weber carbs and the ignition is a Jerry Woods massaged OEM distributor fired by a Mallory Hyfire CD box and a MSD Blaster coil. Ceramic coated headers from Brumos and a M&K 2 in 2 out muffler handle the exhaust. I have done all the work myself except for the paint and I'm real proud of the car she looks great. She sports 911 M calipers on all four corners with 20mm vented discs.Suspension has full Elephant Racing makeover with polybronze bushings. She has 19mm adjustable front sway bar and Koni shocks in the rear sporting 140 lb. springs. I'm already on my second cup of coffee (IMG:style_emoticons/default/biggrin.gif) as I wait for TC, Brian Cheney and my friend Gene to show up at 9:00 to start the install. It's been a long journey and it's not over yet but today is a big step forward! I'll post some pics once the engine bay is full ! (IMG:style_emoticons/default/beerchug.gif)
Jeffs9146 |
Jun 13 2009, 11:49 AM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
QUOTE a 1978 911 3.0 motor in N.C. that I purchased. Induction is 40mm Weber carbs Did you change the cams? If you didn't, I am curious how the power range feels? I am building a very similar motor and the cams seem to be a point of discussion when switching to carbs so I cant wait to hear what you think! |
jt914-6 |
Jun 13 2009, 07:28 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
QUOTE a 1978 911 3.0 motor in N.C. that I purchased. Induction is 40mm Weber carbs Did you change the cams? If you didn't, I am curious how the power range feels? I am building a very similar motor and the cams seem to be a point of discussion when switching to carbs so I cant wait to hear what you think! On my 3.0 I'm using Cosworth pistons-10.5/1 compression, Web cam "S" grind #149, 40mm Webers, recurved OEM dist., MSD 6AL, Blaster coil, Raceware rod bolts, Dilivar studs, built on a 930/68 (3.3 turbo-factory replacement-it has no serial number) case. It runs and feels really good. |
Lo-Fi Version | Time is now: 6th June 2024 - 06:36 AM |
