UPDATE: NOT clutch or tranny... still need your help |
dflesburg |
Jun 14 2009, 03:36 PM
Senior Member Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
pedal up and lots of pedal pressure but...
engine revs and nothing happens like its not in gear. I know its in gear because I can feel the gears with the shifter. the car responds like the clutch is pressed in all the time. The pedal is stiff as hell and the cable is tight. The bearing arm moves. But when I let the clutch out with the motor off and the car in gear, the car rolls . what could that be? |
dkjens |
Jun 14 2009, 05:13 PM
Member Group: Members Posts: 159 Joined: 24-November 08 From: Pasadena, CA Member No.: 9,785 Region Association: None |
Check your CV joints, one may have let go. The driver side outer let go on mine and it felt exactly that way. When I took it apart I expected to find a pile of metal pieces, but everything was intact, including the cage. Somehow the cage had spun and allowed the axle to spin. The inner race had a nasty scar on one edge.
Lo-Fi Version | Time is now: 1st June 2024 - 12:48 PM |
