2.0 Fuel Injectors, Got stiffed on used what about these? |
tracks914 |
Jun 14 2009, 07:14 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
I bought 4 "good used 2.0 injectors" from a member on this site last winter. Yesterday I went to test them before installing them and found 1 out of 4 worked. The others are seized tight.
I think I will buy new ones and saw these on EBay. 912 2.0 and these 1.8 or 2.0 ??? or these AA Pythons Have any of you bought these and tried them? Where would you recommend?? |
kkid |
Jun 15 2009, 01:41 AM
Member Group: Members Posts: 343 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California |
I bought a set of green top injectors at the swap meet the other day and asked Rich @ Cruizin for cleaning them as my back up. He replied;
Injectors don't like to set for long periods of time whether they have been cleaned or not. I've tested brand new injectors that have set for extended periods and many times they will be stuck closed. I flush the injectors with a paraffin based oil after I service the injectors and that helps protect them but even that doesn't last for long periods of time. The best suggestion I have would be to wait to have the injectors serviced when you are ready to use them. If you decide to have them serviced and store them for use later, I would suggest putting a desiccant bag in with the injectors and seal them in a "zip-lock" bag. That still won't protect them forever but it might allow them to set longer. What a great advice! |
Cevan |
Jun 15 2009, 06:24 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
I bought a set of green top injectors at the swap meet the other day and asked Rich @ Cruizin for cleaning them as my back up. He replied; Injectors don't like to set for long periods of time whether they have been cleaned or not. I've tested brand new injectors that have set for extended periods and many times they will be stuck closed. I flush the injectors with a paraffin based oil after I service the injectors and that helps protect them but even that doesn't last for long periods of time. The best suggestion I have would be to wait to have the injectors serviced when you are ready to use them. If you decide to have them serviced and store them for use later, I would suggest putting a desiccant bag in with the injectors and seal them in a "zip-lock" bag. That still won't protect them forever but it might allow them to set longer. What a great advice! I had the same thing happen. I had 4 2.0 injectors cleaned by Rich at Cruzin Performance and then they sat in the sealed bags for 4-5 months. When I went to use them, one was stuck. He suggested using a 9 volt battery and if that didn't work, to send it back to him. 9 volt battery didn't work so off it went to him (same day turn around) and it's worked perfect ever since. I would spend the $75 to have them tested and cleaned. |
Lo-Fi Version | Time is now: 1st June 2024 - 04:43 AM |
