Suggestions on best way to reinstall brake reservoir lines? |
ChrisFix |
Jun 19 2009, 08:41 AM
Member Group: Members Posts: 173 Joined: 3-March 05 From: Chapel Hill, NC Member No.: 3,707 |
Hi,
I'm replacing my master cylinder with a new ATE 17mm...in reading up on how to do this, it seems the one difficult step is re-installing the reservoir lines. What are the "best practices" for doing this from you seasoned pros? In looking over the new MC, I noticed if I removed the rubber boot for the reservoir line, there is a small washer under it that easily gets out of place and prevents the boot from re-seating properly...so it would seem that pulling the boot out and putting over the reservoir line and then inserting the line with the boot attached might be problematic... Anyway, I need to get this done today and not spend the entire afternoon fighting with it, so any suggestions from those who have already fought (and won) this battle would be greatly appreciated. Thanks in advance, Chris |
ArtechnikA |
Jun 20 2009, 10:19 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
if it's not too late to help you (that is, if you are still fighting it...) this is way easier if you attach the lines to the MC on the bench where you can see what you're doing and have leverage to press down. Then snake the lines back up to the reservoir and reattach.
ChrisFix |
Jun 20 2009, 11:45 AM
if it's not too late to help you (that is, if you are still fighting it...) this is way easier if you attach the lines to the MC on the bench where you can see what you're doing and have leverage to press down. Then snake the lines back up to the reservoir and reattach. Thanks for the suggestion...I've already installed it and followed the advice above to simply remove the bracket from the reservoir, which allowed me to pull down the lines enough to easily insert them from under the car, and then carefully pulled them back up already installed. This worked well and was pretty easy. |
Lo-Fi Version | Time is now: 1st June 2024 - 06:34 AM |
