valve adjustmentment screw gone, i am a danger to myself and others |
nycchef |
Jun 22 2009, 11:41 AM
mechanical moron Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None |
while searching for the cause of the incessent popping in my carbs, i decided to check my valves. turns out the adjustment screw for the # 4 exhaust is MISSING. i don't know how i did this having adjusted the valves last year before installing the engine. also the nuts on the rest of the rocker assembly are not 13mm , they are larger and possibly american. what the hell do i have here and can i replace the #4 exhaust screw or do i have to pull out the whole assembly.
SLITS |
Jun 22 2009, 11:49 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
You can buy the adjuster screws new, well, at least the 10mm ones.
A quick look at Pelican Parts site revealed this: Valve Adjustment Screws 043-109-451 Valve Adjustment Screw, 8mm, 8 Per Car, 914 1.7L (1970-73), Each $4.00 [More Info] 022-109-451 Valve Adjustment Screw, 10mm, 8 Per Car, 914 1.8L/2.0L (1973-76), Each $7.95 [More Info] 999-034-005-00-M36 Valve Adjustment Screw Lock Nut, 8mm, 914 1.7, 8 Per Car (1970-73), 914-6, 12 Per Car (1970-72), Each $0.25 Brand: Febi [More Info] 028-109-453-OEM Valve Adjustment Screw Lock Nut, 10mm, 8 Per Car, 914 1.8/2.0 (1973-76), Each $1.25 Brand: Genuine Porsche [More Info] |
nycchef |
Jun 22 2009, 11:53 AM
You can buy the adjuster screws new, well, at least the 10mm ones. A quick look at Pelican Parts site revealed this: Valve Adjustment Screws 043-109-451 Valve Adjustment Screw, 8mm, 8 Per Car, 914 1.7L (1970-73), Each $4.00 [More Info] 022-109-451 Valve Adjustment Screw, 10mm, 8 Per Car, 914 1.8L/2.0L (1973-76), Each $7.95 [More Info] 999-034-005-00-M36 Valve Adjustment Screw Lock Nut, 8mm, 914 1.7, 8 Per Car (1970-73), 914-6, 12 Per Car (1970-72), Each $0.25 Brand: Febi [More Info] 028-109-453-OEM Valve Adjustment Screw Lock Nut, 10mm, 8 Per Car, 914 1.8/2.0 (1973-76), Each $1.25 Brand: Genuine Porsche [More Info] i have an entire extra rocker assembly but it has 13mm nuts how do i remove the screw from the assembly it sticks after a few turns and fear i wuill strip it. |
Lo-Fi Version | Time is now: 29th May 2024 - 04:41 AM |
